EEPROM verify failure
Hi
I am new to this forum and basic stamp in general, I have searched for help on this subject
but have been unable to find anything, sorry if it is a simple or obvious or answered question.
I have the BS2 on a GROWBOT board which I am trying to get to know how to use.
It only has the 2 servos, 2 led's and piezo speaker.
I have writen and dowloaded a few basic programs which worked and ran OK so I am sure that I
am doing everything correctly, all of a sudden when attempting to download it responds with a
"EEPROM verify failure" error message
Does this mean the EEPROM is damaged, it has only been written too a few hundred times?
How do I go about fault finding this?
Thank you in advance
Jeff
Jeff
Causes:
1. Worn out EEPROM. Only happens if you've been using the "WRITE" command.
2. Loose cable.
3. Flaky connection IN the cable.
4. Low power supply/low battery
5. Bad grounding -- either serial cable to board, or battery to board, or both.
Thank you for the detailed response, I should be able to fault find it now.
No great thing is created suddenly. - Epictetus (A.D.200)
www.biodieselsolutions.co.za
