Connector Pin Testing...
Question? I'm trying to design a connector pin tester using a BS2. I've learned in the past to present this type of project in Forums, because why re-invent the wheel or start making the same mistakes others have made. Help! I want to preform insulation resistance 5,000 to 100,000M ohms with approximately 500V and dielectric withstanding voltage 500 to 3000V with minimum breakdown or leakage at approximately 2mA -- all variables should be variable. Testing will be pin to pin and pin to shell -- up to 200plus pins (again variable). I know that one of the post dealt with check if wire(s) were "HOT". I'm looking at something similar. HELP!
Shoe-horning 200 plus pins and controlling 500 to 3000 volt supplies while measuring their current sounds like an awful lot to expect out of this extremely reliable, but fairly limited platform.
Thanks... OptoDragon
It also did a hi-pot of each conductor.
The prototype actually ran on a Sinclair ZX81 and the final version was used with a Tandy 100 (one of the first laptops). The printout had a serial number attached to it and it printed out the status of any failed pins.
Its not a trivial project, but should be doable on a BS2sx or BS2px and some creative use of multiplexing to get the number of pins you need. Start with a few conductors, get the test sequences working then increase the number of conductors.
Cheers,
Tom Sisk
http://www.siskconsult.com
