How do i launch a object in the new cog? check out this code
Whats wrong with the code it wont launch the lcd.init
Now if i do this it works
My problem is that I dont want to keep running lcd.init when I update the
"Pub Dispaly (Info,Mode,Time)" from my main code.
this line will continue to be updated form another object
Update Example
con
slow = 60_000_000 'Led flashing speed slow
fast = 2_000_000 'Led flashing speed fast
On = 1
Off = 0
LEDPIN = 20 'Led Pin
Var
Long Stack[noparse][[/noparse]32]
obj
lcd :"LCDdriver"
fs : "floatString"
PUB start (Info,Mode,Time) : success
dira[noparse][[/noparse]pin]~~
lcd.init
lcd.cls
Success := Cognew(Display(Info,Mode,Time),@stack)
Fs. SetPrecision(4)
If (Mode == 0)
lcd.pos(1,1)
lcd.writestr(@screen)
lcd.writestr(fs.Floattostring(Info))
lcd.pos(2,1)
lcd.writestr(@screen1)
waitcnt(Time + cnt)
lcd.cls
If (Mode == 10)
lcd.cls
lcd.pos(1,1)
lcd.writestr(@Flashscreen1)
lcd.pos(2,1)
lcd.writestr(@flashscreen2)
pause_it(5,factor1)
waitcnt(Time + cnt)
lcd.cls
DAT
screen1 byte "Top of",eos
screen2 byte "Value = ",eos
Flashscreen1 BYTE "Software",eos
Flashscreen2 Byte "Version 3.2",eos
dira[noparse][[/noparse] pin ]~~
lcd.init
lcd.cls
Fs. SetPrecision(4)
If (Mode == 0)
lcd.pos(1,1)
lcd.pos(2,1)
waitcnt(Time + cnt)
lcd.cls
If (Mode == 10)
lcd.cls
lcd.pos(1,1)
lcd.pos(2,1)
pause_it(5,factor1)
waitcnt(Time + cnt)
lcd.cls
there is a difference in the methodnames
the PUB-definition is named "Dispaly"
in your cognew statement it is named "Display"
looks like a mistyping
you did not post your complete code as an attachment
so there are some questions left:
where is constant "pin" defined ?
could it be that there is a method display that still exists but you made all the changes inside Dispaly ??
Your code-snippet has a method PUB start (Info,Mode,Time) : success
Is this the TOPLEVEL object ?
Then the parameters are not initialized in the code-snippet.
the code that is posted in the first post: is this the COMPLETE code ?
I don't think so. Could you please post ALL files as an attachment.
This means: your mainfile AND LCDDriver.spin AND floatstring.spin AND whatever else is depending on those files?
best regards
Stefan
