SHT-11 code help
Hello All,
To get this Sensirion SHT-11 sensor tested quickly I copied Tracy's code from his site to the editor.
all I get is wrong values in the DeBug window. Here is what results I get:
-40.0·· 65535·· %RH=3731.7····· %RHtc=3715.2
I have tripple checked the code and I do not see the problem.
Help.
Here is the code.
D. A. Wreski
Help.
Here is the code.
D. A. Wreski
You have sck and dta as CON 4 and CON 6, instead of PIN 1 and PIN 0?
Your OUTS and DIRS under initialization are different, confirm....
~~ dRu ~~
I have Pin 1 and Pin 0 set for another use.
I then removed the OUTS and DIRS from the program, that are not necessary for the program to work. Still the same results.
I did scope the Clock and Data pins on the SHT11 and the Stamp ports 4 and 6 and I do see data and clock. Somehow
the data is incorrect. Is there a timming problem?
I even tried another program with the same results. I do not see why P4 and P6 won't work as well as P0 and P1.
Thanks for your reply. I need another set of eyes, I might be overlooking something simple?
Dave
a quick look and found.......
~~ dRu ~~
D. A. Wreski
I have found the problem. All the samples I used have the pinout for the sensor itself. Parallax has the SHT-11 sensor on a 8 pin carrier with a different pinout.
So, as soon as it was connected properly everything works. Parallax has built in protection resistors so the external resistors are not needed.
Thanks for all the help.
D. A. Wreski
