TV output current requirements
Using a standard TV output adapter(1.1K, 570, 220 ohm resistors), about how much current is used? I am prototyping a project and need my power requirements pretty low. I will sometimes connect a tv to the device to check certain things, but don't want the TV object to run all the time if it is using power. Since the TV output·components form a DAC, some pins will source while others sink current. I don't want to have to code in extra features if it's not needed.
So, how much current does the TV output take(not counting extra cog)?
Cooresponding currents of - 0, 5.54, 4.38, 2.62, 5.54, 4.38, 2.62, and 0.(220ohm---(570||1100), 570ohm---(220||1100), etc.)
I just calculated it in an excel sheet, and it seems the average current would be... 3.136mA... WHOA! That's way more than I expected. I would have imagined somewhere in the 100uA's range. I guess only a proper REAL measurement will be the final say, but wow. Thanks Mike.
Doing the math, it should be about 11.68mA peak, but the average(over a period of time) should be 3.136mA. Still, a lot of current just for a signal.
If you really want to get into the math, calculate a curve of the statistical distribution of brightness, and use the power dissipation for each brightness value, then integrate. In my job as an engineer , I don't integrate. I design around worst-case unless cost pressures force me to be more precise.
Post Edited (Ken Peterson) : 6/28/2008 4:24:46 AM GMT
That's only for one specific colour ( or control level ) so the average, unless you're unlucky would be less than that.
