H48C Oddness (SOLVED)
I am trying to make a self-keeping accelerometer package with the H48C Accelerometer Module. Everything is working fine, except the Z axis seems to be always reporting +1g. The other to axes are reporting more sane values. I have sat my Propeller on the ground, and with a 600 sample average, X= -0.018, Y= 0.033, and Z= 1. I am using V1.1 of the H48C Driver. Is there some calibration I need to do, or is my code messed up?
EDIT: I have left Zero-G unconnected, and left out the 220 Ohm resistors for the pins. I know this might damage the prop, but I do not have any on hand.
Code:
I am 1011, so be surprised!
Advertisement sponsored by dfletch:
Come and join us on the Propeller IRC channel for fast and easy help!
Channel: #propeller
Server: irc.freenode.net or freenode.net
If you don't want to bother installing an IRC client, use Mibbit. www.mibbit.com
Post Edited (tpw_man) : 6/27/2008 11:20:46 PM GMT
Code:
con
_clkmode = xtal1+pll16x
_xinfreq = 5_000_000
obj
accel : "H48C Tri-Axis Accelerometer"
lcd : "Debug_LCD"
math : "FloatMath"
str : "FloatString"
var
long x,y,z
long x2,y2,z2
pub main
str.setprecision(2)
accel.start(0,1,2)
lcd.init(15,19200,4)
lcd.cls
lcd.backlight(true)
average(600)
pub display(num)
lcd.str(string("X_Gforce= ",13,"Y_Gforce= ",13,"Z_Gforce"))
repeat num
lcd.gotoxy(10,0)
lcd.str(str.floattostring(math.fdiv(math.ffloat(accel.x),math.ffloat(455))))
lcd.str(string(" "))
lcd.gotoxy(10,1)
lcd.str(str.floattostring(math.fdiv(math.ffloat(accel.y),math.ffloat(455))))
lcd.gotoxy(10,2)
lcd.str(str.floattostring(math.fdiv(math.ffloat(accel.z),math.ffloat(455))))
'output(accel.x,accel.y,accel.z, 1)
waitcnt(clkfreq/10+cnt)
pub average(num)
lcd.str(string("Averaging..."))
lcd.home
repeat num
x += accel.x
y += accel.y
z += accel.z
output(x/num,y/num,z/num, 0)
'repeat
pub output(x_,y_,z_, t)
if t == 0
lcd.cls
lcd.gotoxy(10,0)
lcd.str(str.floattostring(math.fdiv(math.ffloat(x_),math.ffloat(455))))
lcd.gotoxy(10,1)
lcd.str(str.floattostring(math.fdiv(math.ffloat(y_),math.ffloat(455))))
lcd.gotoxy(10,2)
lcd.str(str.floattostring(math.fdiv(math.ffloat(z_),math.ffloat(455))))
Channel: #propeller
Channel: #propeller
