Extended_FDSerial Question...
Below is the Method that just wont work.·
ExtendedSerial.RxStrtime(5000,@buf)
Here is the method that runs the above statement above.·
** Code **
PUB RxStrTime (ms,stringptr) : Value | ptr, temp
· Accepts a string of characters - up to 15 - to be passed by reference
· Allow timeout value.
· String acceptance terminates with a carriage return or defined delimter character.
· Will accept up to 15 characters before passing back.
· Serial.RxstrTime(200,@MyStr)··· ' accept
· serial.str(@MyStr)············· ' transmit
··· ptr:=0
··· bytefill(@dataIn,0,70)
··· bytefill(stringptr,0,70)····························
·· temp :=· RxTime(ms)·······
·· if temp <> -1
····· dataIn[noparse][[/noparse]ptr] := temp
····· ptr++··················································
····· repeat while (((DataIn[noparse][[/noparse]ptr-1] <> 13) and (DataIn[noparse][[/noparse]ptr-1] <> Delimiter)) and (ptr < 71))·······················
········· temp :=· RxTime(ms)···
········· if temp == -1
············ ptr++
············ quit···
········· dataIn[noparse][[/noparse]ptr] := temp
········· ptr++
····· dataIn[noparse][[/noparse]ptr-1]:=0·······································
····· byteMove(stringptr,@datain,ptr-1)··
·- Was it pin 11 or 26?· Hmmm....··I think the smell of smoke tells the whole story.· Must be 26.
Michael King
Application Engineer
R&D
Digital Technology Group
** Code **
··· ptr:=0
·· if temp <> -1
············ ptr++
········· ptr++
Michael King
R&D
Why the BYTEFILLs? Did you change them? They clear "dataIn" and the "buf" for 70 bytes each. Why 70 bytes?
I know I am getting data in because I can display the data but only for a couple of packets and then it stoppes working. Any suggestions?
Michael King
R&D
As in
Packet Radio , the old AX25
Microtor
Sitor
Pactor
Plain old RTTY
Wireless networking (I think not, but maybe you are using PINK)
Some other obscure mode often used with STL's
GMDSS also comes to mind another nasty piece of work !!
etc...etc...etc
It sounds more like a modem configuration problem to me. Only guessing but we don't have a lot the work with. I presume it is a modem and not a TNC. I am sure there are many who can help, once the problem is fully understood.
Ron
You will need to post your entire program (please ... as an attachment, not as the text of a message).
The routine you posted, other than the mismatch between the comment description and how the code works, looks ok. If you're using FullDuplexSerial, you may be having problems with buffer overflow since the default buffer size is only 16 bytes and, if you don't empty it soon enough, it will just wrap around. You can increase the buffer to any power of 2 by changing a few lines of code. There are some alternate versions of FullDuplexSerial in the Object Exchange that already have this done.
Post Edited (Mike Green) : 6/26/2008 5:03:14 PM GMT
