Propellent search path
For Jeff,
Most programs look in the user's "current directory" for files specified on the command line. Propellent does not.
I put propellent.exe in a directory in my path, cd to another directory containing source to compile, and run propellent to compile, propellent looks for the file in the propellent directory unless I specify an absolute path for the file to compile. This is not "typical" command line behaviour; can you address this?
Thanks.
Thanks.
Having to spend time finding a solution was slightly annoying. The environment was a Makefile.
