How about this F-sram? — Parallax Forums
  • LeonLeon Posts: 7,620
    edited 2008-06-23 13:27
    Nice devices. They've been around for years.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
  • Marcel P.Marcel P. Posts: 2
    edited 2008-06-23 15:28
    Are they applicapable for us? Espacially as Video Ram
    edited 2008-06-23 15:45
    They're not fast enough for use as video ram. For that you need a fast parallel ram which uses a lot of I/O pins. They also don't publicize enough that read cycles are destructive. Every time you read a location, the chip has to write it back. That's not too much of a problem because the write process is very fast, but it does count against the number of write cycles the device can handle before it wears out. If you're using it for a high speed refresh process, that's a lot of read cycles.
  • Leslie (HA4WV)Leslie (HA4WV) Posts: 6
    edited 2008-06-23 16:13
    According to me to a video generator the undermentioned memory type useful:
    http://pdfserv.maxim-ic.com/en/ds/DS1270AB-DS1270Y.pdf
    Leslie
    HAM Radio callsign: HA4WV
    edited 2008-06-23 16:14
    Mike Green said...
    Where did you see that the number of write cycles is limited? I have always thought that they had a virtually unlimited number of write cycles, it's one of their selling points.
    Leon
    edited 2008-06-23 16:28
    See this App Note: www.ramtron.com/files/tech_papers/Endurance%20of%200.5u%20FRAM%20Products.pdf.
    The FRAM chips do have a very high number of write cycles, much higher than EEPROMs, but you do need to think about endurance when you're doing high speed repetitive operations on the memory.
    edited 2008-06-23 17:09
    The FAQ says "F-RAM experiences 1E12 read/write cycles or greater."
    Leon
    Post Edited (Leon) : 6/23/2008 5:28:53 PM GMT
  • evanhevanh Posts: 17,221
    edited 2008-06-24 09:08
    Have a look at MRAM for the do it all option. Although, it's still got a ways to go to get the density right up there but the prediction is it will compete with Flash/DRAM and eventually replace both them and SRAM.
    Which means it could replace CMOS entirely. And have your Prop made from it. [noparse]:)[/noparse]
    Here's a prediction of 2015 I guess.
    Evan
    edited 2008-06-24 10:22
    evanh said...
    Or maybe not. MRAM is not really a logic relevant construction. Also, it seems they are using CMOS fabs to make the stuff anyway. The two techs integrate nicely I presume.
    Evan
    edited 2008-06-24 12:03
    Here's a comparison chart of one manufacturer's status.
    I note they use 10^16 for SRAM/DRAM endurance figures. This is clearly a number that is overly conservative. And I think that'll apply just as much to the 10^15 figure used for MRAM. I guess that's as far as lab testing has gone for each.
    As far as I understand MRAM has unlimited endurance just like SRAM/DRAM have.
    Evan
