Servo Pal and BOE Question
We are running 4 full size servos off of two Servo Pals connected the BOE using a standard Basic Stamp. The problem we are see appears to be a power related problem. If we connect two servos up they function well; as soon as we attach the other two we get very jerky / uncontrollable behavior. We suspect that we are exhausting the power capabilities to power the servos.
So, my question is. Can the BOE w/ 2 servo pals run 4 full size hobby servos with the supplied AC adapter? (I think it's 12v, but it may be a little less).
If not, then how do you supply additional power to the servos on the BOE?
Thanks for your help!
Sean
Sean
Note: Do not use an unregulated supply in this configuration. You could easily exceed the maximum operating voltage of both the servos and ServoPAL.
