ELSEIF to turn a light on or off
I'm using the DS1302 as the real time chip.
I'm trying to write an ELSEIF which I would like to use to turn a light on and off. I'm writing something which is not correct.
I would like the light to come on at 8am and go off at 9pm
if hour > x then
high 14
elseif hour < x then
low 14
else ?
endif
If anyone can help that would be great
thanks,
chris
Greenhouse Project
Post Edited (Shadowcasterx4ffc) : 6/20/2008 2:21:49 PM GMT
if hour > x then
high 14
low 14
else ?
endif
thanks,
chris
Greenhouse Project
You didn't describe any of the rest of your program or the hardware involved. Assuming that you read an external
real time clock at least once a second (into hour)
This works because hour will be 8 for one hour and it doesn't matter if you do a high if the pin is already high or
a low if the pin is already low.
Sorry for the confusion, we're using the DS1302 as our timekeeping chip.
Greenhouse Project
IF hour > 8 AND hour < 21 THEN HIGH light ELSE LOW light
Is there some particular reason you want to use ELSEIF?
Tracy Allen
www.emesystems.com
