Solid Block Character? — Parallax Forums
johnfl68johnfl68 Posts: 72
edited 2008-06-23 18:28 in Propeller 1
Am I missing something, or is there not a solid block character (inverse of the space) in the font set?
John
    edited 2008-06-18 21:28
    Set forground to background and background to forground, or if you are using the tile driver set a color value where the foreground and background is swapped.
    Paul Baker
  • CassLanCassLan Posts: 586
    edited 2008-06-18 21:29
    Well, it depends how you look at it.
    I have not seen one, but you can just change the forground/background color and use the space.
    edited 2008-06-18 21:31
    You are correct. However, if you need a solid block to display on video from a Propeller program, you can just display a space with inverted colors.
  • johnfl68johnfl68 Posts: 72
    edited 2008-06-18 22:03
    ARrrrgg - then I have to lose a color - as I have the color space full already.
    Oh well, I'll think of another solution.
    Thanks!
    John
  • RaymanRayman Posts: 16,215
    edited 2008-06-19 01:06
    I have an app and sample code for custom characters here:
    http://www.rayslogic.com/propeller/Programming/InterleavedCharacter.htm
    edited 2008-06-23 16:27
    Good point, defining a character that is full foreground would work, requires 16 times the amount of memory to do, but it can be done.
    Paul Baker
  • simonlsimonl Posts: 866
    LOL, your tongue musta been firmly planted in your cheek there Paul!
    Cheers,
    Simon
    www.norfolkhelicopterclub.co.uk
    You'll always have as many take-offs as landings, the trick is to be sure you can take-off again ;-)
    BTW: I type as I'm thinking, so please don't take any offense at my writing style smile.gif
