Propeller Mini Development Board
Hey guys, I've designed a new development board for the Propeller.
Check it out...
Features:
· USB powered (PTC Fused at 250mA for USB port protection)
· Small size: 1.8" x 3.75" (not including connectors)
· Programmable LED (Red)
··RCA for video output
··PS/2 connector (uncommitted)
· 3-Pin header for 5V LCD
· Ground Lug for oscilloscope
· Breadboard area with access to Gnd,3.3V,5V and P0 to P11 on both sides
· 64KB EEPROM (32K for data storage)
[noparse][[/noparse]Edit] Added PDF document
Bean.
"A government big enough to give you everything you want, is big enough to take away everything you·have."·· Thomas Jefferson
"It is our choices, Harry, that show what we truly are, far more than our abilities."·Dumbledore from Harry Potter
www.iElectronicDesigns.com
Post Edited (Bean (Hitt Consulting)) : 7/10/2008 11:44:51 AM GMT
Check it out...
Features:
Bean.
That could be very handy popped into the side of my laptop!!
I have a few questions:-
Is it 5MHz crystal?
What power rating is the regulator?
Target price?
Coley
PropGFX Forums - The home of the Hybrid Development System and PropGFX Lite
It is designed to provide 200mA from the 3.3V regulator. I'll check this to see what the limit is before either the regulator shuts-down or the PTC trips.
Price is not firm, but should be in the $59 range. It depends on alot of factors.
Bean.
Uhhhm, that was on fire when I got here...
Current Projects:
Robot Control Via Skype API - Dev Stage(50% Complete) - Total(25%)
Robot Localization Via Xbee's - Research Stage
IR Tracking with Propeller - Research Stage
I don't know how many people will do that, but that is the idea.
Plus I already have 1000 USB-A connectors
P.S. The board will come with a USB extension cable too.
Bean.
Post Edited (Bean (Hitt Consulting)) : 6/19/2008 6:48:05 PM GMT
Robert
Bean.
You can draw 200mA from the 3.3V supply all day long.
At I was able to use 225mA, but at 250mA the thermal fuse opened. Simply removing the load and everything started back up again. You gotta love those PTC fuses.
The 5V supply is through the same PTC, so that is a TOTAL of 200mA from both the 5V and the 3.3V supplies.
Bean.
I finally looked at the schematic. If there's a revision B, you really should put a series resistor in the clock and data lines from the PS/2 connector. I know you can use a resistor as a jumper from the header to the Propeller I/O pin header, but IMHO, it would have been more useful to not have the header, have a 100 or 220 Ohm resistor, then a direct line to a pair of otherwise unused I/O pins.
By the way, do you have an estimated price yet?
· Oops. I missed that on the schematic. There ARE series resistors to the header pins.
· I didn't have a easy way to connect to any of the propeller pins, so I took the easy way out...But it does leave your options open.
· I'll get the schematic fixed asap.
· Preliminary price is $69.95. And comes with a 3' (1M) USB extension cable.
Bean.
Thanks for catching that Mike.
P.S. Production boards will be blue instead of green too.
Bean.
what is the bottom of the board like? is it just the bottom of the PCB? I like to mount boards like this on some thing to prevent me setting it on something and shorting it out. are mounting holes an option?
"A complex design is the sign of an inferior designer." - Jamie Hyneman, Myth Buster
DGSwaner
Post Edited (Dgswaner) : 7/13/2008 9:17:10 PM GMT
I need to do some maintence on the website, I'll put it on then. They should be available in about 4 weeks.
Bean.
One thing I notice about your designs is that you keep 90-degree corners in your routes.· I guess I by second nature now make all my corners at·least 135·degrees because I was taught that 90-degree corners can cause worse signal reflection.· Have you ever heard this?
Maybe you have found·that for your projects the corner sharpness doesn't matter.
Thanks for any feedback.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
<.-.>Braden<.-.>
That is a ground lug/post. Makes it easy to connect your scope's ground clip when testing signals. These types of posts are also used as test points on some boards.
It's Only A Stupid Question If You Have Not Googled It First!!
And they will available for purchase then too.
Soon guys...Very soon.
Bean.
I'll get some picture tomorrow.
But they are here, I just need to get them on the website.
Bean.
Perhaps FemtoBASIC "color" might work as well?
PICS! Don't tease us! [noparse]:)[/noparse] [noparse]:)[/noparse]
OBC
New to the Propeller?
Getting started with a Propeller Protoboard?
Check out: Introduction to the Proboard & Propeller Cookbook 1.4
Got an SD card connected? - PropDOS
They look like the pic in the first post, only BLUE instead of green (by suggestion of Ken G).
My goal is to get femtoBASIC running on them for the expo. It shouldn't be too hard. Famous last words...
They will be door prizes at the expo as well (5 or so).
Price will be $69.95. This is the same as the Prop Dongle but the Prop Mini Dev Board has a breadboard, PS/2 and RCA built-in. Only drawback is a 64K EEPROM (Prop Mini Dev Board) instead of a 128K EEPROM (Prop Dongle).
Bean.
Try this version.. I'm curious if it works on your board...
http://forums.parallax.com/showthread.php?p=690283
OBC
· I'll try it as soon as I can.
· Here is a picture of the production boards. I'll try to get them on the website this weekend.
· They come with rubber feet and a 3' USB extension cable for $69.95 each + $10.00 for shipping any qty.
· If anyone wants one of these first ones, feel free to paypal payment to terry@hittconsulting.com
Bean.
Whit+
You should just have to change the I/O pin numbers for the PS/2 interface and the video output, then recompile FemtoBasic.
It'll ignore the absence of an SD card although you could add one to any group of 4 I/O pins and change the pin numbers in the program to match.
You could also run DongleBasic on it although then it wouldn't use the video output or PS/2 interface.
