High Frequency with BS2
Hi all,
I'm trying to count high frequencies of 150 to 250 KHz into the BS2, and having read the manual and varying posts about the maximum allowable frequency of 120 KHz, I wanted to know if there was a way to work around that. My first idea was to count positive edges only or every other transition. I was wondering if this would work considering that the frequency might still be too fast to catch all the positive edges. My second idea was to cut down the frequency by a known factor using an IC, but I don't know of any relatively cheap ones I can buy and use. I would appreciate if anybody had any companies/prices. Thanks for your help.
A simple divide by 10 counter is the 4510 (www.doctronics.co.uk/4510.htm). These sell for maybe 40 cents from Jameco, Digikey, or Mouser. There are all sorts of other counters that would be good alternatives depending on your particular circumstances.
You'd only need one counter, either a divide-by-4 as Phil suggested or a divide-by-10 or divide-by-16.
