Another Function Question — Parallax Forums
Mike WMike W Posts: 105
edited 2008-06-18 16:18 in General Discussion
I wanted to declare the following subroutine as a Function because I wanted it to return two variables signF and degF
I need more information about using FUNC and ENDFUNC.
And the RETURN degF, signF command before the endfunc
I am currently using SXB 1_51_03 The help file doesn’t really·get into·their use
I am familiar with using the label followed by a colon: (GET_TEMP[noparse]:)[/noparse] and ending with return
GET_TEMP·········· ··············· FUNC··············· 2, 0········· ······························· ··············· ' read temperature
FUNC GET_TEMP·········· ······························· ······························· ··············· ··············· ' read temperature in celsius and
·· Temp_Reset = 1······································ ····································································· ·' convert to fahrenheit
··· SHIFTOUT Temp_I_O, Temp_Clock, LSBFIRST, StartConvert·························· ·' start conversion
·· Temp_Reset = 0······················································
·DO······························································································
·· Temp_Reset = 1······················································
··· SHIFTOUT Temp_I_O, Temp_Clock, LSBFIRST, ReadConfig·························· ·' command read configuration register
···· SHIFTIN Temp_I_O, Temp_Clock, LSBPRE, tmpB1············ ······························ ' bit7 Wait for conversion to complete
·· Temp_Reset = 0······································ ··································································· ' 0 = still converting
·LOOP UNTIL tmpB1.7 = 1·········· ······························· ······························· ··············· ·' 1 = conversion complete
· Temp_Reset = 1························································
··· SHIFTOUT Temp_I_O, Temp_Clock, LSBFIRST, ReadTemp········· ··············· ' command read converted temperature
···· SHIFTIN Temp_I_O, Temp_Clock, LSBPRE, degC·············································' get celsius temp 8 bits
···· SHIFTIN Temp_I_O, Temp_Clock, LSBPRE, signC\1······· ······························ ' get celsius sign 1 bit 1=neg 0=pos
·· Temp_Reset = 0·······························································································
··· IF signC = 1 THEN···················· ······························· ··············· ····························· ' when degrees celsius goes negitave
···· degC = ~degC· ······························· ······························· ······································ ·' you need to convert degC from
··· ENDIF··············· ······························· ······························· ··············· ······················· ·' 2's compliment
···· tmp2 = degC.0· ······························· ······························· ······································· · ' save degC half bit
····· degC = degC >> 1······················· ······························· ··············· ·························· ·' remove half bit
··········· tmpW1 = degC */ $01CC····· ······························· ········································ · ' degC x 1.8 (9/5)
············ degF = tmpW1_LSB ······· ······························· ··············· ································ ·' if .5 degrees celsius
············ degF = degF + tmp2········· ······························· ··············· ······························· ·' then add 1 to degF
········ IF signC = 1 THEN····································································
·········· IF degF >= 32 THEN·································································
··········· degF = degF - 32·······································································
············ signF = NEGATIVE···········································································
·········· ELSE···············································································
··········· degF = 32 - degF······································································
············ signF = POSITIVE·············································································
·········· ENDIF························································································
·········· degF = degF + 32··············································································
········ ENDIF··········································································································
·RETURN··············· degF, signF·····················································································
ENDFUNC
  • JonnyMacJonnyMac Posts: 9,809
    edited 2008-06-18 03:30
    I beg to differ... if you go into the help file section called Definitions, you will find details and examples on using SUBroutines and FUNCtions in SX/B.
  • Mike WMike W Posts: 105
    edited 2008-06-18 06:27
    JonnyMac
    Thanks for the reply however I have read through the help files and am still unclear on when I need to use the syntax
    FUNC Label
    or just
    Label:
    I realize that if you dont user the (FUNC Label) that you cannot use the ENDFUNC after the return. I just dont understand the correct usage·or the·advantages over one or the other.
    If I define A function, and then label it with only A colon after the Label what happens.
    mike
  • BeanBean Posts: 8,129
    edited 2008-06-18 13:04
    Mike,
    How are you trying to assign the function results ?
    Please post the entire program... It makes things alot easier when we don't have to guess what you're trying to do.
    Bean.
    Uhhhm, that was on fire when I got here...
    www.iElectronicDesigns.com
    edited 2008-06-18 15:41
    I have posted the latest version of my program. I would be happy to provide any other info needed. If need be I would try to restate my question.
    edited 2008-06-18 15:55
    Mike,
    When you use a function you usually use "var = functionname" this sets "var" to the value returned by the function.
    Bean.
    I added two lines after Start: I think this is what you mean I did not post the whole program again only the change.
    All I wanted to do is display these two values (degF, signF) to a lcd display. which it did as a sub I am mearly trying to understand if it would be better programing by using the Function definition
    Start:········'
    · PLP_C = %00000111······' pull up unused pins
    · LcdOut = 1 ·······' make output pin high
    · WAIT_MS 100·······' let lcd initialize
    degF = GET_TEMP
    signC = GET_TEMP
    As always Thank You
