switches only work "when the want to"
Hello I have two random switches that I found and I am using a 220 and a 10k ohm resistor set up, for some reason the program only reads them every so often, when i run a led to the switch if turns on and off every time with the switch. I am using a BS2, does anyone have any ideas for trouble shooting? Thanks
