StampPlot
Is it possible to use StampPlot with an SX?
I presume if you could emulate the BS2's Debug function in the SX then you might be able to get it to work.
If not, is there anything about that would enable me to do the same things that StampPlot can do (I'm trying to do the Process Controls tutorials for the BS)?
Any thoughts?
Any thoughts?
I'll have to have a bit of a play to see if I can get it working - no time now though!
Shawn Lowe
When all else fails.....procrastinate!
FYI there are a couple of examples of TTL to serial devices in the documentation section·for the SX chip in the article Beginning Assembly Language for the SX Microcontroller in appendix B "Hardware"
http://www.parallax.com/Default.aspx?tabid=460
Jeff T.
If you're using a short connection you can use N9600 (inverted) mode to connect directly to the PC.
Shawn Lowe
Shawn Lowe
