single pin video generated output
I did some calculations on the following schematic to see if
video level signals could be generated with one pin.
+5V o--[noparse][[/noparse] R1 ]----+
pin o--[noparse][[/noparse] R2 ]----+· level
···············[noparse]/noparse] 75[color=white]·[/color
················ V
pin·· signal·· level
·L··· sync·····Vs
·I··· black··· Vb = 0.3 + Vs
·H··· white··· Vw = 1.0 + Vs
white:
···· 75
* 5 = 1.0 + Vs
75 + (R1//R2)
black:
··75
* 5 = 0.3 + Vs
75 + R1
sync:
·· (75//R2)
* 5 = Vs
(75//R2) + R1
If you work this out, the results are (exactly !):
R1 = 175 ohm
R2 = 210 ohm
Vs = 1.2V
Vb = 1.5V
Vw = 2.2V
Has anyone tried this, and does the 1.2V dc offset bother the video input
(I believe not because these are mostly ac coupled).
regards peter
················ V
·L··· sync·····Vs
white:
···· 75
* 5 = 1.0 + Vs
75 + (R1//R2)
black:
··75
* 5 = 0.3 + Vs
75 + R1
sync:
·· (75//R2)
* 5 = Vs
(75//R2) + R1
R1 = 175 ohm
R2 = 210 ohm
Vs = 1.2V
Vb = 1.5V
Vw = 2.2V
regards peter
http://forums.parallax.com/showthread.php?p=598779
www.sxvm.com
my own boards. Just wandering if someone did a one-pin
setup, as the timing code needs to be altered quite a bit due
to the fact that changing pin direction takes a lot more
cycles than changing pin output level.
regards peter
That should work. But I'd be more inclined to run it through a transistor driver. The reason is that, by relying on the pin tri-stating, your source impedance is constantly changing. This could have an impact with long cable runs. With a transistor driver, you can get a 75-ohm source impedance, without having to fiddle with the resistor divider values. Higher-valued divider resistors also put less stress on the microcontroller pin, and the transistor isolates it somewhat from transmission line issues.
Attached is a sample schematic. It's an emitter follower whose source impedance is determined largely by the collector resistor. This circuit will output a 1V p-p signal regardless of whether the monitor it's feeding is properly terminated. Due to the interposed B-E junction, the sync tips will be at 0.6V instead of 1.2V.
What does the [noparse][[/noparse] 75 ] represent?
James Newton, Host of SXList.com
james at sxlist,com 1-619-652-0593 fax:1-208-279-8767
SX FAQ / Code / Tutorials / Documentation:
http://www.sxlist.com Pick faster!
Phil, thanks for the driver schematic. It made me realise that
if a video input is indeed ac coupled, without the driver I
possibly would never get a stable·1.2V dc offset because the cap would
charge/discharge dependant on video frame content. The driver
does provide a stable 1.2V sync tip level at the transistor base.
(I have seen video inputs where the cap is the first component blocking all dc current,
although most video inputs·have a 75ohm resistor to gnd before the cap that allows dc current
to flow).
Still want to know if someone has done such a one-pin setup
and has some working code in either asm or sxb.
regards peter
Most devices that receive video signals have a DC-restorer (clamp) after their AC coupling stage, which firmly plants the sync tips at a known level. This is necessary for the very reason you mention: that the average DC level depends on the video content — but regardless of how its driven. The main benefit from the driver is presenting a constant impedance to the transmission line.
20MHz if you could make a circuit that generated sync when the pin was an input. I don't know how you would do that without a negative voltage though.
Bean.
Did you know that 111,111,111 multiplied by 111,111,111 equals 12345678987654321 ?
www.iElectronicDesigns.com
