Generate Object Code
Is there a tool for the Propeller that will allow one to generate a self loading binary image of the compiled program? Something a la “Generate Object Code…” of the Basic Stamp.
If you distribute it as an eeprom file, then you could use something like HAM.
http://forums.parallax.com/showthread.php?p=628778
OBC
New to the Propeller?
Getting started with the Protoboard? - Propeller Cookbook 1.4
Got an SD card? - PropDOS
Need a part? Got spare electronics? - The Electronics Exchange
Note: This program is a 5 minute knock together and has not been thoroughly tested and it requires the DotNet 2.0 Framework to be installed.
