graphics_drv_010 how to?
browsing around I found graphics_drv_010.spin and I believe it is what I was looking for (I didn't try it yet).
I understood (corrrect me if I am wrong) that it is used with Hydra...which I do not have...where can I find some example on how to use graphics_drv_010?
It is correct to sey taht it prepare a piece of "bitmap" that I can use to create graphic for any other display (programming an appropriate interface of course [noparse]:)[/noparse] )
Thanks!!!
Thanks!!!
If you install the Parallax Propeller Tool, you will find the same spin code, for demo board, you can modify and use as you like.
The HYDRA code and assets come with the book and HYDRA systems. They are not for general distribution.
Run the graphics_demo program you will find in the Propeller tool examples. Depending on your setup, you will have to edit the pin definitions.
Chat in real time with other Propellerheads on IRC #propeller @ freenode.net
graphics_drv_010.spin was released in the "Hydra Source Code Teaser" in Obex.
as such it has already been set free..
obex.parallax.com/objects/102/
However, the Hydra book is VERY worth the purchase and does grant
personal license to all of the Hydra objects (on CD).
OBC
New to the Propeller?
Getting started with the Protoboard? - Propeller Cookbook 1.4
Got an SD card? - PropDOS
Need a part? Got spare electronics? - The Electronics Exchange
