wire guage? — Parallax Forums
wire guage?
Fred HawkinsFred Hawkins Posts: 997
edited 2008-06-15 04:33 in Propeller 1
What are the ramifications of using 30 guage enameled wire to wirewrap prop circuits? Specifically, I am thinking about using it with rgb LED's.
  • LeonLeon Posts: 7,620
    edited 2008-06-14 16:54
    You need proper wire-wrap wire which forms a cold weld at the corners of the posts.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
    edited 2008-06-14 17:03
    Magnet wire?·
    Seriously?·
    Scraping the varnish at the ends like that and all?
  • Ken PetersonKen Peterson Posts: 806
    edited 2008-06-14 17:06
    @Fred: If the enamel is thin enough, the wrapping processes may join the wire to the post. Go ahead and try it out. You may still want to consider wire-wrap wire as Leon said.
  • Fred HawkinsFred Hawkins Posts: 997
    edited 2008-06-15 00:22
    Turns out the spool that I tried first is 26 guage which is just as well, the 30 is nearly geezer-proof in terms of visibility. I used a lighter to remove about 3/8 inch of enamel before wrapping.
    Leon, consider me a radio shack victim. I once asked for wrap wire and they gave me 3 little spools of 30, 26 and 22 guage.
    Ken, I hadn't thought of just wrapping without removing the enamel. I'll try it.
  • Beau SchwabeBeau Schwabe Posts: 6,574
    Fred Hawkins,
    If your plan is to make the wire wrap "permanent", some enamel coatings burn off quite nicely with just the heat from soldering, other enamels are a bit more stubborn.
    Beau Schwabe
    IC Layout Engineer
