Scribbler IR detection
Does anyone know how to use the scribbler program?· I need help with getting the IR leds and the sensor to stop the bot from hitting the wall and I can mostly do all of the other commands but the Distance detection is the one that stumps me.
Check the 8 kb file under Writing Programs (.pdf) and Sample Code (.zip), which has many small programs·worth studying, including the EYETEST program I'm attaching here, which uses the two IR LEDs and the center IR receiver module as object detectors.·Good luck!
