Ddr ram
Has anyone looked at making a board to interface DDR RAM with microcontrollers?
I've just been looking at the pinouts and it looks like there are 64 data pins, 16 or 17 address pins, some bank pins and a couple of clock and other pins needed. How hard would it be for someone to come up a board like Andre's SRAM board for DDR ram?
But it depends on the uC. The propeller can talk to external devices in parallel at 5 or so MT/s ... not more, reliably. (would have been great if it had a way of high bandwidth communications...)
The only way I found was if you have a CPLD or similar that takes care of generating addresses, refresh and so on, that you serve an address and maybe a length and it serves you with data, if well synchronized, maybe 10 MT/s or at clock speed...
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
I've got stacks of DDR and even if 80% of it was wasted in the use
it would still be worth it!
OBC
New to the Propeller?
Getting started with the Protoboard? - Propeller Cookbook 1.4
Got an SD card? - PropDOS
Need a part? Got spare electronics? - The Electronics Exchange
Things are much more complex than for asynchronous DRAM.
DDR is wandering into FPGA territory. And, if your using an FPGA, you might as well just put the processor on it anyway.
Ack, that all sounded ranty, sorry about that.
Jimmy
Post Edited (Jimmy W.) : 6/15/2008 8:42:31 PM GMT
Jimmy: To loose is not the same as to lose.
You loose a bolt unscrewing it, but if you lose it... you have to get a new one
