How do you use the serial port on the board of education?
Hi All,
··· How do you use the serial port on the board of education? Also, I am connecting a XBee to this port if anyone has some sample code would be helpful.
Thanks In Advance
[noparse][[/noparse]Topic Subject Added By Moderator]
Post Edited By Moderator (Chris Savage (Parallax)) : 6/13/2008 10:35:34 PM GMT
Thanks In Advance
The xBee cannot be directly connected to the programming port on the BOE since that's RS232 and the xBee uses 3.3V logic.· You need to have some kind of level translation.· In addition, the echo will probably cause problems unless you pre-configure the xBee separately so it provides a simple wireless serial "pipe".· In that case, you'll still get the echo, but it won't bother the xBee.
So I will need to build my own connection then. Can that be done and can the Board I have deliver the 3.3 volts I need?· This is a link to a interface board I got.
http://microcontrollershop.com/product_info.php?cPath=297&products_id=2369
Post Edited (kenwtn) : 6/13/2008 6:44:20 PM GMT
