PropDOS to get pseudo directories / Need input
Oldbitcollector (Jeff)
I'm working on a new concept in PropDOS, pseudo directories.
Since FSRW is a ways from supporting folders, I'm putting together an update to PropDOS
which will help with the huge mess of files on my SD card. Anyone else here?
Here's what I've got in mind..
Addition of the following commands..
MKDIR <folder> -- This will create a hidden .DIR text file that will be empty.
COPY filename <folder> -- This will place an entry in the hidden .DIR text file, (maybe prevent it from display at the root.)
DEL filename -- Will continue to remove the physical file, also remove it from hidden .DIR texts.
CD <folder> -- will open the proper text file for DIR to list it's contents.
This will be a temporary measure until greater minds than mine can add true folder support in FSRW.
Gmail users could think of this as a type of Gmail "Labels" instead of folders.. [noparse]:)[/noparse]
Comments? Suggestions?
OBC
New to the Propeller?
Getting started with the Protoboard? - Propeller Cookbook 1.4
Got an SD card? - PropDOS
Need a part? Got spare electronics? - The Electronics Exchange
OBC
If you do something with this I'll fix up PropBash to work with the changes.
Post Edited (stevenmess2004) : 6/13/2008 7:19:01 AM GMT
the DIR.file if it is selected. The CD and CD .. command moves you in and out of the file.
I'm redirecting F1 and DIR to display the virtual directory, while F4 and DIR/W
will show the actual root.
I'll leave it up to the users if you want to select a virtual directory as your root.
It should be ready in a day or so.
OBC
Surely adding directory support to fsrw shouldn't be *that* hard. I won't have time to do it, probably, for a long time, but
I could perhaps help a little bit in answering questions and/or guiding the solution.
I mean, fsrw *already* reads one directory; reading other directories is truly not that different, and adding code to
manage the current working directory, add path searching, etc. shouldn't be hard.
If you forgo mkdir/rmdir in the initial cut that makes it even easier (people can always mkdir/rmdir on another
computer if they want).
Exactly my thoughts. I'm playing with the idea of actually implementing directory support ... I did it before (complete VFAT FS in VP asm), so it can't be that hard [noparse];)[/noparse]
In the meantime, I'm adding a "LABEL" command which will allow easy sorting of files,
and CD to view them. [noparse]:)[/noparse]
OBC
