Angular momentum drive system timing?
In my recent post i mentioned adding energy to the drive system by having an off balance disc rotating in the y-z plane. As the weight goes through the bottom of its rotation it would be at the same time the robot is in a stride and thus add energy to the springs in the legs, as the robot come off the ground, the weight would be going through the top of its rotation giving the robot energy in the positive z direction. how would you design a control system that changed the rotational speed of the weight to match the period of the stride and flight sequence?
plauseable but I belive a centrifical clutch like that on a gocart and a digitaly controled brake calliper would need be used to pull the sequence into alignment such a mechinisem would shred meshed sprockett's at a direction or speed change and the disk itself would have to great a centrifical force to be reduced and sped back up in a useable time frame useing any motor without a brake ,at the same time the amount of applied brake and the durration of brake will also change angular momentum like a motocross rider aplies rear brake to bring the nose down on landing or gases it in the air to bring nose up.
love to see this in action..goodluck.
watching horses ,dog's any fourleged creature in stride youll notice that the neck&head extend upward as the ground is pulled to the aft end then the neck&head ducks down as they reach out for new ground this is while they are runing"galloping" and front and back legs are paralell with each other, but when a horse starts to trot the neck goes sharply back and the aft end rolls under as the back streightens and action becomes slightly out of sequence like two men carrying a sofa.. spend an hour playing fetch with a dog you'll see my point ,just maybe this walk method can be duplicated without sophistocated mechanizems by simply following form&proportion..
either way I like where your going with it..
Post Edited (iamdenteddisk) : 6/13/2008 10:22:23 AM GMT
mostly the question is, do we have current technology capable of doing it this way. if not we need someone to try(experiment), so technology can catchup.
P.S., sorry to take so long to come back to this forum and reply..
If you wanted to increase the amount of energy stored/released with an oscillating mass an off balance disk driven by a motor whose rpm is controlled by a pulse width modulated driver would be mechanically simpler.
