4x20 LCD Problem
babinda01
Hello
I have begun my first project with the prop, and have run into my first problem (I am sure I will have more).· I am using a 4x20 LCD display which has the ks066 control, which I am told is compatible with the HD44780.· I am using the LCDDEMO which I have found in the object exchange, and I have got the display working a little.· My problem is that it is just writing·lines 1 and 3 and not to lines 2 and 4.· Does anyone know what I am doing wrong?? Do I need to change the line addresses???
Andrew
Andrew
can you post the relevent portions of your code here?
If i'm not mistaken it should look like this
Thanks for your input, but I am still having troubles.
Here is a snippit of the code.
· LCD.init····················· 'Initialize the display
· LCD.pos(1,1)················ 'Set the third line position
· LCD.writestr(@text)·········· 'Write the first string
· LCD.pos(2,1)················ 'Set the third line position
· LCD.writestr(@next1)········· 'Write the second string
· LCD.pos(3,1)················ 'Set the third line position
· LCD.writestr(@try1)·········· 'Write the third string
· LCD.pos(4,1)················ 'Set the third line position
· LCD.writestr(@last)·········· 'Write the fourth string
dat
text····· byte· "Andrew", eos
next1··· byte "Was", eos
try1····· byte·"Here", eos
last····· byte "Today",eos
The result of this is that Andrew is displayed on line 1 and Here is displayed on line 3, but lines 2 and 4 are blank.
Andrew
I guess you're using the "LCDDEMO Version 1.2 April 21,2007 "
Please DO NOT tied the D0..D3 lines to gnd, only use the D4..D7 lines of the LCD, and keep the others data lines open, that I think, will solve your problem.
Try it please.
Regards.
Alberto.
I have working code for a 4*20 HD44780 LCD
If you can let me know your pin assingments I will adapt my code to suit so that you can test your setup.
Coley
PS Alberto is right, D0..D3 must be left un-connected, unless you are in 8 bit mode of course!!!
PropGFX Forums - The home of the Hybrid Development System and PropGFX Lite
i took a look inside a manual of a 4x20 Display.
DD-RAM-ADRESSES to chacterposition in the display
4x20
Line 1 $00-$13
Line 2 $40-$53
Line 3 $14-$27
Line 4 $54-$67
As you can see from the adresses it starts with line 1 and then next ADRESS is Line 3
then there is a gap from $28 to $39 and then comes line 2 and line 4
For analysing your display you should do some systematical tests
set cursor to first line first columm
make loop that repeats four times
inside this loop write another loop that sends 20 characters
starting with A,B,C, twenty letters
for sending the characters to the display
do NOT use LCD.writestr()
use the method that sends a SINGLE character
These two nested loops will send 80 characters to the display.
Look on the display what will be displayed.
If you do not understand how the characters are mixed up take a photo of the display and post it here.
I'm not sure about which object you are using
"LCD Driver HD44780 16x2 4 bit 8 bit DEMO" and "Parallel LCD Driver"
don't have methods named "writestr" or "pos"
Also if your code is not top secret attach ALL the files that are nescessary to compile the WHOLE project
The it will be much easier to analyze the whole thing.
best regards
Stefan
Thanks for everyones assistance, it is greatly appreciated.· Alberto wins the apple pie.......
I had tried D0-D3 to ground, and this was causing my problems.· Thanks again Alberto.
Regards
Andrew
Regards.
Alberto.
display, you can specify the position, length and formatting
of each field.
It requires debug_lcd,Simple_Numbers,FloatString,FloatMath, so make
sure they are in your library search path.
Example Usage:
OBJ
LCD : "LCD"
VAR
long debug1,debug2,debug3,debug4,debug5,debug6,debug7,debug8
PRI Main
SetupLcd
repeat
debug1:=cnt
PRI SetupLCD | LCD_PIN,LCD_BAUD,LCD_LINES,LCD_BACKLIGHT_PIN,LCD_BACKLIGHT_SECONDS
LCD_PIN := 27
LCD_BAUD := 19_200
LCD_LINES := 4
LCD_BACKLIGHT_PIN := LCD#NO_BACKLIGHT_PIN
LCD_BACKLIGHT_SECONDS := 0
LCD.Stop
LCD.Setup(LCD_PIN, LCD_BAUD, LCD_LINES,LCD_BACKLIGHT_PIN,LCD_BACKLIGHT_SECONDS)
LCD.SetPrecision(4)
'line 1
LCD.AddField( 0,0,string("A") , 2,0,@debug1 ,LCD#LONG_,8,0)
LCD.AddField(10,0,string("B") ,12,0,@debug2 ,LCD#LONG_,8,0)
'line 2
LCD.AddField( 0,1,string("C") , 2,1,@debug3 ,LCD#LONG_,8,0)
LCD.AddField(10,1,string("D") ,12,1,@debug4 ,LCD#LONG_,8,0)
'line 3
LCD.AddField( 0,2,string("E") , 2,2,@debug5 ,LCD#LONG_,8,0)
LCD.AddField(10,2,string("F") ,12,2,@debug6 ,LCD#LONG_,8,0)
'line 4
LCD.AddField( 0,3,string("G") , 2,3,@debug7 ,LCD#LONG_,8,0)
LCD.AddField(10,3,string("H") ,12,3,@debug8 ,LCD#LONG_,8,0)
LCD.Start
I am having another little problem, that I am hoping someone can help me with.
I am quite happy sending constants to the lcd using either LCD.writestr(@Splash1), where @Splash1 is stored in the dat area as·Splash1···· byte "CNC Control Pendant",cr,eos·or by·LCD.writstr(string("CNC Control Pendant",cr, eos)).· But now I am wanting to display data that I am recieving from a serial device -·I am using·FullDuplexSerial.· I have the following code where I want to display on the LCD the string for the recieved data, but I am not sure how to a. convert to a string the serial data and b. how to dispay a variable using lcd.writestr.
I hope all that made sense.
repeat
···· if ser.rxcheck
······ ch:=ser.rx ' get char
······ lcd.pos (4,10)
Andrew
