Some advice needed to write modified data back into the boot eeprom for usage a — Parallax Forums
Christof Eb.Christof Eb. Posts: 1,597
edited 2008-06-11 18:36 in Propeller 1
Hi, I would be very thankful for some help!
I want to do the following:
PUB main
a:=b*var1     'use predefined variable
var1:= xyz     'modify predefined variable
writeback(@var1,1)    ' ??????? IS THERE A FUNCTION TO WRITE BACK A MODIFIED LONG INTO THE BOOT EEPROM?????
DAT
var1   long   27     'have a variable in a dat-section with predefined data
Thanks alot for some input!
Christof
    edited 2008-06-11 17:08
    Look in the Propeller Object Exchange under the topic Data Storage. You'll find several objects that can be used to write to (or read from) EEPROM. If you write the variable back to the same location in EEPROM as it has in RAM (@var1), then, when the program next loads, the variable will have the new value.
  • Christof Eb.Christof Eb. Posts: 1,597
    Thank you, Mike,
    I was not aware, that it was such simple, perhaps someone is looking for something too. So I post the solution
    Christof
    CON
      i2cSCL        = 28
    '  i2cSDA        = 29
      EEPROMAddr    = $A0
    OBJ
      i2cObject      : "basic_i2c_driver"
    PUB main
        evar1++   'Modify the variable
        writeback_long(@evar1)
    PUB writeback_long(adr) | eepromlocation, eepromData
        eepromlocation:= adr
        eepromData:=     LONG[noparse][[/noparse]adr]
        i2cObject.WriteLong(i2cSCL, EEPROMAddr, eepromLocation, eepromData)
    DAT
    evar1                   long    42
