serial input
Hello all,
I can send·data using the 912Mhz transceiver.
the basic layout is:
·propeller --> wireless tx --> wireless rx --> bs2
I tried using a prop at the receiving end but I'm a bit over my head on this.
You can see the spin program (for wireless tx) is simple:
·· every 4 seconds the chip sends out 8 bits of data serially
On the other hand,·the spin program (for wireless rx) is pretty bad:
When the data is recieved, each bit is saved in a part of an array.
Then every 4 seconds·this array displays the value.
I even tried to string together the separate parts - see valone.
Does anyone have any suggestions to do this better?
Shmow
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
BaudRate = 9600
TxPin = 4
VAR
byte Serial_Value
OBJ
BS2 : "BS2_Functions" ' Create BS2 Object
PUB Wireless_Output
dira[noparse][[/noparse]16]~~
Serial_Value := 255
repeat
outa[noparse][[/noparse]16]~~
waitcnt(clkfreq*3+cnt)
BS2.serout_dec(TxPin,Serial_Value,BaudRate,1,8)
waitcnt(clkfreq+cnt)
CON
TxPin = 1
RxPin = 0
VAR
byte DataIn[noparse][[/noparse]10]
byte SerDataIn[noparse][[/noparse]10]
byte valone
long stack[noparse][[/noparse]1000]
OBJ
SER : "FullDuplexSerial"
SIO : "FullDuplexSerial_2"
PUB Wireless_Input
SER.Start(0,20,0,9600)
cognew(7, Hyper_Terminalt, @stack[noparse][[/noparse]100])
repeat
SerDataIn[noparse][[/noparse]0] := IN_SIO.rx
SerDataIn[noparse][[/noparse]1] := IN_SIO.rx
SerDataIn[noparse][[/noparse]2] := IN_SIO.rx
SerDataIn[noparse][[/noparse]3] := IN_SIO.rx
SerDataIn[noparse][[/noparse]4] := IN_SIO.rx
SerDataIn[noparse][[/noparse]5] := IN_SIO.rx
SerDataIn[noparse][[/noparse]6] := IN_SIO.rx
SerDataIn[noparse][[/noparse]7] := IN_SIO.rx
valone := (10*serdatain[noparse][[/noparse]0])+(serdatain[noparse][[/noparse]1])
PUB Hyper_Terminal
SIO.start(31, 30, 0, 57600)
repeat
dataIn[noparse][[/noparse]0] := SerDataIn[noparse][[/noparse]0]
dataIn[noparse][[/noparse]1] := SerDataIn[noparse][[/noparse]1]
dataIn[noparse][[/noparse]2] := SerDataIn[noparse][[/noparse]2]
dataIn[noparse][[/noparse]3] := SerDataIn[noparse][[/noparse]3]
dataIn[noparse][[/noparse]4] := SerDataIn[noparse][[/noparse]4]
dataIn[noparse][[/noparse]5] := SerDataIn[noparse][[/noparse]5]
dataIn[noparse][[/noparse]6] := SerDataIn[noparse][[/noparse]6]
dataIn[noparse][[/noparse]7] := SerDataIn[noparse][[/noparse]7]
ser.tx(10) 'line feed
ser.tx(13) 'carriage return
ser.str(string(" Results = ")) 'display decimal value of temp
ser.dec(datain[noparse][[/noparse]0])
ser.dec(datain[noparse][[/noparse]1])
ser.dec(datain[noparse][[/noparse]2])
ser.dec(datain[noparse][[/noparse]3])
ser.dec(datain[noparse][[/noparse]4])
ser.dec(datain[noparse][[/noparse]5])
ser.dec(datain[noparse][[/noparse]6])
ser.dec(datain[noparse][[/noparse]7])
ser.str(string(" Binary value is "))
Shmow
