em-408 GPS prop interface
I have a em-408 from spark fun im trying to interface with the prop....
I first tried it alone hooked up to the prop using GPS VGA object from the obex...
i got nothing...
To test the gps i made a 3232 based circiut and tested it on the computer it works fine...
Im just reading the gps not writing to it...
has anyone used a 406 or 408 gps unit with the prop and GPS to vga object?
Jesse
i got nothing...
Jesse
You should also do a search for gps using search.parallax.com/. there is a lot of good information out there.
hardware wise i just have vss and vdd properly hooked up i have the enable pin on the gps high.... and i have the rx on the gps set high with a 3.3k resistor between it.. tx hooked up to my rx prop pin.
Ill start digging into the behind the scenes next· but it would just be nice to get the·premade object visually working so i know my hardware etc is ok. will make it easier to learn [noparse]:)[/noparse] the details.
Btw thanks for the sample spin ill dig in soon looks like some other fun stuff in there too.
Jesse
also the connector has several grounds, they must all be connected
Perry
it has a enable which you have to pull high.. rx, tx, 3.3 and gnd only
I think i found an answer in another thread though the gps vga object in the obex just doenst seem to work quite right out of the box.. I'll try looking over and adapting terry hits and the chucks, posted above... Being new to this stuff is tricky when you are not sure if its a code or a hardware issue etc.·
