1-Wire weather problem
I recently purchased a Dallas WS-1 weather instrument (Hobby Boards)and connected it to a BSP24 STAMP microprocessor and am running the OW_weather.BSP program to read the temperature wind speed and direction. When I start the program I can read the temperature but get 0.0 wind speed and direction yields an error.
Any thoughts or help would be appreicated?
tom
[noparse][[/noparse]Subject Added By Moderator]
Post Edited By Moderator (Chris Savage (Parallax)) : 6/10/2008 8:32:13 PM GMT
tom
' File...... OW_WEATHER.BSP
' Purpose... 1-Wire Weather Station Interface
' Author.... Jon Williams / Parallax (portions by Tim Bitson)
' E-mail.... jonwms@aol.com / tbitson@mac.com
' Started... 13 DEC 2001
' Updated... 06 JAN 2002
' { $STAMP BS2p }
[noparse][[/noparse] Program Description ]
' This program reads and displays the sensors from a Dallas 1-Wire Weather
' Station.
' NOTE: The 1-Wire bus requires a very stiff pull-up -- 1 kOhm or less.
[noparse][[/noparse] Revision History ]
' 15 DEC 2001 - Version 1 working
' 06 JAN 2002 - Updated error handling for bad wind vane
[noparse][[/noparse] I/O Definitions ]
OWpin CON 15 ' 1-Wire bus
[noparse][[/noparse] Constants ]
' 1-Wire Support
OW_NoRst CON %0000 ' no Reset
OW_FERst CON %0001 ' Front-End Reset
OW_BERst CON %0010 ' Back-End Reset
OW_BitMode CON %0100
OW_HighSpd CON %1000
ReadROM CON $33 ' read ID, serial num, CRC
MatchROM CON $55 ' look for specific device
ODMatchROM CON $69 ' overdrive match rom
SkipROM CON $CC ' skip rom (one device)
SearchROM CON $F0 ' search
' DS1820 control
CnvrtTemp CON $44 ' do temperature conversion
RdScratch CON $BE ' read scratchpad
' DS2423 control
ReadMemCntr CON $A5 ' read memory + counter
' DS2450 control
ReadMem CON $AA ' read memory
WriteMem CON $55 ' write memory
Convert CON $3C ' do conversion
NoDevice CON %11 ' no device present
CommOkay CON 1
NoComm CON 0
Celsius CON 0
Fahrenheit CON 1
TMode CON Fahrenheit ' temperature display mode
DegSym CON 176
MoveTo CON 2 ' DEBUG cursor positioning
LF CON 10 ' linefeed
[noparse][[/noparse] Variables ]
devCheck VAR Nib ' device check return ocde
commStat VAR Bit ' comm status
sensor VAR Nib ' current sensor to display
eeAddr VAR Word ' string pointer in EE
char VAR Byte ' character to print
idx VAR Nib ' loop counter
romData VAR Byte(8) ' ROM data to devices
tempIn VAR Word ' raw temperature
sign VAR tempIn.BIT11 ' 1 = negative temperature
tLo VAR tempIn.LOWBYTE
tHi VAR tempIn.HIGHBYTE
tSign VAR Bit
tempC VAR Word ' Celsius
tempF VAR Word ' Fahrenheit
cntrA VAR Word ' wind count start
cntrB VAR tempIn ' wind count end
rps VAR tempC ' revs per second
speed VAR tempF ' wind speed
crc16 VAR tempIn
verify VAR char
direction VAR tempC
dFlag VAR tempF.LOWBYTE
rjNum VAR Word ' number to right justify
width VAR Nib ' width of field
rjSign VAR Bit
digits VAR Nib
[noparse][[/noparse] EEPROM Data ]
DS1820 DATA $10,$15,$32,$09,$00,$08,$00,$A9 ' temp sensor
DS2423 DATA $1D,$82,$43,$01,$00,$00,$00,$6F ' wind speed
DS2450 DATA $20,$AF,$FF,$00,$00,$00,$00,$5E ' wind direction
CommUp DATA "... Up", 0
CommDn DATA ". Down", 0
WindDir DATA " N", 0, " NNE", 0, " NE", 0, " ENE", 0
DATA " E", 0, " ESE", 0, " SE", 0, " SSE", 0
DATA " S", 0, " SSW", 0, " SW", 0, " WSW", 0
DATA " W", 0, " WNW", 0, " NW", 0, " NNW", 0
BadDir DATA "Error", 0
[noparse][[/noparse] Initialization ]
Initialize:
DEBUG CLS ' open DEBUG window
PAUSE 250
Splash_Screen:
DEBUG HOME
DEBUG "==================================", CR
DEBUG " BS2p <--> 1-Wire Weather Station ", CR
Charge_Station:
INPUT OWpin
IF (INS.LOWBIT(OWpin) = 0) THEN Bus_Shorted ' possible wiring problem
HIGH OWpin
DEBUG MoveTo, 0, 4, "Charging station..."
FOR idx = 10 TO 1
DEBUG MoveTo, 20, 4, DEC idx, " "
PAUSE 1000
NEXT
INPUT OWpin
DEBUG MoveTo, 0, 4, REP " "\25
Weather_Labels:
DEBUG MoveTo, 0, 4, "Comm.......... "
DEBUG MoveTo, 0, 6, "( ) Temperature... ", CR
DEBUG MoveTo, 0, 7, "( ) Wind Speed.... ", CR
DEBUG MoveTo, 0, 8, "( ) Direction..... ", CR
[noparse][[/noparse] Main Code ]
Main:
GOSUB Comm_Status ' check 1-Wire comm
IF (commStat = CommOkay) THEN Show_Sensors
PAUSE 2000
GOTO Initialize ' "reboot" if comm went down
Show_Sensors:
GOSUB Flag_Sensor ' show sensor in use
BRANCH sensor, [noparse][[/noparse]Show_Temp, Show_Wind_Speed, Show_Wind_Dir]
Main2:
sensor = sensor + 1 // 3 ' select next sensor
GOTO Main
END
[noparse][[/noparse] Subroutines ]
' A shorted condition on the 1-Wire bus has been detected
' -- we can't charge the station cap in this condition
Bus_Shorted:
DEBUG CLS, "The 1-Wire bus is shorted.", CR
DEBUG "Please repair before continuing.", CR
END
' Print status of 1-Wire comms
Comm_Status:
eeAddr = CommUp ' assume bus is up
commStat = CommOkay
GOSUB Device_Check ' check bus for devices
IF (devCheck <> NoDevice) THEN Print_Comm
eeAddr = CommDn
commStat = NoComm
DEBUG MoveTo, 19, 6, REP " "\15 ' clear station data if down
DEBUG MoveTo, 19, 7, REP " "\15
DEBUG MoveTo, 19, 8, REP " "\15
Print_Comm:
DEBUG MoveTo, 12, 4 ' show comm status
GOSUB Print_String
RETURN
' Check for presence of 1-Wire devices
' -- does not search for ROM codes
Device_Check:
devCheck = 0
OWOUT OWpin, OW_FERst, [noparse][[/noparse]SearchROM]
OWIN OWpin, OW_BitMode, [noparse][[/noparse]devCheck.BIT1,devCheck.BIT0]
RETURN
' Indicate sensor in use
Flag_Sensor:
DEBUG MoveTo, 1, 6, " " ' clear previous mark
DEBUG MoveTo, 1, 7, " "
DEBUG MoveTo, 1, 8, " "
DEBUG MoveTo, 1, (6 + sensor), "*" ' mark current sensor
RETURN
' Transfer OW serial number to RAM
' -- point to SN with eeAddr
Load_SN:
FOR idx = 0 TO 7 ' load ROM pattern
READ (eeAddr + idx), romData(idx)
NEXT
RETURN
' Retrieve and display temperature
Show_Temp:
eeAddr = DS1820 ' load device serial number
GOSUB Load_SN
OWOUT OWpin, OW_FERst,[noparse][[/noparse]MatchROM, STR romData\8, CnvrtTemp]
HIGH OWpin ' extra juice during conversion
PAUSE 750
INPUT OWpin
OWOUT OWpin, OW_FERst,[noparse][[/noparse]MatchROM, STR romData\8, RdScratch]
OWIN OWpin, OW_BERst,[noparse][[/noparse]tLo, tHi]
tSign = sign ' save sign bit
tempIn = tempIn >> 1 ' round to whole degrees
IF (tSign = 0) THEN NoNeg1
tempIn = tempIn | $FF00 ' extend sign bits for negs
NoNeg1:
tempC = tempIn ' save Celsius value
tempIn = tempIn */ $01CC ' multiply by 1.8
IF (tSign = 0) THEN NoNeg2 ' if neg, extend sign bits
NoNeg2:
tempF = tempIn + 32 ' finish C -> F conversion
DEBUG MoveTo, 19, 6 ' move cursor to temp display
rjNum = tempF ' prep for right justified print
width = 5 ' five digits wide
GOSUB RJ_Print
DEBUG " ", DegSym, "F"
GOTO Main2
' Retrieve and display wind speed
' -- mph = rps * 2.453
Show_Wind_Speed:
eeAddr = DS2423
GOSUB Load_SN
' get starting count
OWOUT OWpin, OW_FERst, [noparse][[/noparse]ODMatchROM]
OWOUT OWpin, OW_HighSpd, [noparse][[/noparse]STR romData\8, ReadMemCntr, $DF, $01]
OWIN OWpin, (OW_HighSpd | OW_BERst), [noparse][[/noparse]cntrA.LOWBYTE, cntrA.LOWBYTE, cntrA.HIGHBYTE]
PAUSE 2500 ' = revs for 5 seconds
GOSUB Comm_Status
IF (commStat = CommOkay) THEN Get_End_Count
GOTO Main2 ' abort if comm down
' get ending count
Get_End_Count:
OWIN OWpin, (OW_HighSpd | OW_BERst), [noparse][[/noparse]cntrB.LOWBYTE, cntrB.LOWBYTE, cntrB.HIGHBYTE]
Calc_CPS:
rps = cntrB - cntrA ' get diffential count
IF (cntrB >= cntrA) THEN Calc_Speed
rps = rps + $FFFF ' correct for rollover
Calc_Speed:
speed = rps */ $04E7 ' rps * 4.906 (tenths @ 5 seconds)
DEBUG MoveTo, 19, 7
width = 3 ' width of whole portion
rjNum = speed / 10 ' get whole portion
GOSUB RJ_Print ' print it
DEBUG ".", DEC1 speed, " mph " ' then print tenths
GOTO Main2
' Retrieve and display Wind direction
Show_Wind_Dir:
eeAddr = DS2450
GOSUB Load_SN
OWOUT OWpin, OW_FERst, [noparse][[/noparse]MatchROM, STR romData\8, WriteMem, $08, $00]
FOR idx = 1 TO 4 ' setup four channels
OWOUT OWpin, OW_NoRst, [noparse][[/noparse]$08] ' 8-bit values
OWIN OWpin, OW_NoRst, [noparse][[/noparse]crc16.LOWBYTE, crc16.HIGHBYTE, verify]
OWOUT OWpin, OW_NoRst, [noparse][[/noparse]$01] ' 5.12 volt scale
NEXT
Start_Conversion:
OWOUT OWpin, OW_FERst, [noparse][[/noparse]MatchROM, STR romData\8, Convert, $0F, $55]
OWIN OWpin, OW_NoRst, [noparse][[/noparse]crc16.LOWBYTE, crc16.HIGHBYTE]
HIGH OWpin ' juice during conversion
PAUSE 10
INPUT OWpin
Get_A2D:
OWOUT OWpin, OW_FERst, [noparse][[/noparse]MatchROM, STR romData\8, ReadMem, $00, $00]
OWIN OWpin, OW_BERst, [noparse][[/noparse]STR romData\8]
Calc_Direction:
FOR idx = 0 TO 3 ' convert readings to word
direction.LOWNIB(idx) = romData(idx * 2 + 1) / 90
NEXT
' convert word to 1 of 16
dFlag = 99 ' preset for error inidcation
LOOKDOWN direction, [noparse][[/noparse]$2220,$1220,$1222,$1122,$2122,$2112,$2212,$2211], dFlag
IF (dFlag < 8) THEN Show_Direction ' found in first table
LOOKDOWN direction, [noparse][[/noparse]$2221,$0221,$0222,$0022,$2022,$2002,$2202,$2200], dFlag
dFlag = dFlag + 8 ' adjust for second table
Show_Direction:
DEBUG MoveTo, 19, 8
eeAddr = BadDir
IF (dFlag < 16) THEN Good_Dir ' found in either table?
GOTO Dir_To_Screen
Good_Dir:
eeAddr = WindDir + (6 * dFlag) ' address of direction string
Dir_To_Screen:
GOSUB Print_String
GOTO Main2
' Print a right-justified number
RJ_Print:
rjSign = rjNum.BIT15
rjNum = ABS(rjNum)
digits = width
LOOKDOWN rjNum,<[noparse][[/noparse]0,10,100,1000,65535],digits
DEBUG REP " "\(width-digits-1), 13 * rjSign + " ", DEC rjNum
RETURN
' Print string at current cursor position
' -- point to string with eeAddr
' -- string is zero-terminated
Print_String:
READ eeAddr, char ' get character from EEPROM
IF (char = 0) THEN Print_String_Done ' if 0, string is done
DEBUG char ' print it
eeAddr = eeAddr + 1 ' point to next character
GOTO Print_String
Print_String_Done:
RETURN
- Stephen
How do I read the actual serial number of the weather instrument.
No data came with the unit. Is there a program to read the serial number, where can I find it?
Where do I insert the serial number?
thanks
TOm
did your unit from hobby boards come with a DS9097U or DS9490R?· If so, you can download the OneWire Viewer software from MAXIM; http://www.maxim-ic.com/products/ibutton/software/1wire/OneWireViewer.cfm
With it, you can see the serial numbers used by the devices in the weather instrument.· If you don't have either, you might want to look into getting one from Hobby Boards... or see if there is some·serial number search·code for the STAMP already written.· I seem to recall there was some... but search isn't being friendly at the moment.
The good part is that you only need to get the 1-wire serials once. (Write them down)
EDIT:· after a little more searching...
While I could not quickly find the code from parallax,·I found code at MAXIM using the Parallax example to read 1-wire ID's with a Stamp.
There's nothing like a new idea and a warm soldering iron.
Post Edited (pwillard) : 6/11/2008 2:41:20 PM GMT
I ran the 1-wire-ID program and I recevied the following 00 10 01 00 00 00 00 00 in the debug window!
-thus only one code was received not three for the three sensors in the WS-1 wind instrument.
The code lines below are from the the actual Weather On the Wire program to read the three sensors in the weather instrument. I tried inserting the ROM code that I read from above ID program into the Ow_weather program exerpted below in either the wind speed or wind direction and nothing changes.
I can only read the temperature and nothing else. Is the ID code read supposed to read all three codes from the DS1820,DS2423 and the DS2450?
What gives?
DS1820········· DATA··· $10,$15,$32,$09,$00,$08,$00,$A9········ ' temp sensor
DS2423········· DATA··· $1D,$82,$43,$01,$00,$00,$00,$6F········ ' wind speed
DS2450········· DATA··· $20,$AF,$FF,$00,$00,$00,$00,$5E········ ' wind direction
- Stephen
The temp read correctly, the wind spedd reads 0.0 always and the direction reads error
Tom
For what it's worth; I played with this program some time ago, and modified it for my own use. Basically, I changed the serial numbers to match my unit, and added more comments.
I don't recall running into any serious problems, but only wanted to use it as an example.
Go ahead and do a line-by-line comparison to your code, and see where the differences are.
By the way, is the little jumper in or out? (whichever is appropriate)?
Terry
