Backup power suply? — Parallax Forums
Backup power suply?
jmspaggijmspaggi Posts: 629
edited 2008-06-10 19:30 in General Discussion
I would like to add a backup power suply to me Javelin to keep it running in case of power outage. Is there a simple way to do so?
JM
    edited 2008-06-10 14:41
    A quick search of Google will get you some results on simple diode-based circuits that will allow you to have a battery connected to the Javelin that essentially takes over in a power loss situation, however some people opt for another solution…low power UPS systems are very inexpensive these days. You could plug your whole system into one of those and when the mains go out it will take over. With such a small load you could get an hour or more out of it.
  • jmspaggijmspaggi Posts: 629
    edited 2008-06-10 14:48
    Hi Chris,
    Thanks a lot for your reply.
    I searched on Google, but was not able to find anything else than car battery chargers schemas. I think that I'm not using the right key words. Can you just let me know what the name of what I need, so I will be able to google it? I will also look for UPS options.
    Jean-Marc
    edited 2008-06-10 16:02
    A few examples are linked below. I hope this helps. Take care.
    http://schematics.blogspot.com/2006/10/battery-backup-for-sram-or.html
    http://eepn.com/locator/products/ArticleID/32507/32507.html
    http://www.laserforums.com/forum/showthread.php?t=3331&p=44297#post44297
    That helps a lot! Thanks so much. I will do some test to see how I can adapt that to my Javelin.
    JM
