interfacing a BS2e with a 4x4 keypad
I have a 4x4 keypad with 8 pins and a carrier board with a BS2e that I finally got to work, but the code is ugly. I'm looking for a cleaner solution.
The keypad pins are 1 = Col4, 2 = Col3, 3 = Col2, 4 = Col1, 5 = Row1, 6 = Row2, 7 = Row3, and 8 = Row4. I am using the BS2e pins Pin1 = Col1 through Pin4 = Col4 as toggling High and Low and testing Pins 5 to 8 (as Rows 1 to 4) as inputs for the High (I added a 330 ohm in line).
Here is my code (I will develop a parser later):
' KeyPadTest4.bse
' {$STAMP BS2e}
' {$PBASIC 2.5}
' values for rdg and key
' button key rdg
' 1 - 9 1 - 9 1-3, 5-7, 9-11
' 0 0 14
' A - D 10 - 13 4, 8, 12, 16
' * 14 13
' # 15 15
row VAR Byte
col VAR Byte
rdg VAR Word
key VAR Word
oldkey VAR Word
DEBUG CLS, "testing the keypad", CR, CR, CR, " "
DO UNTIL oldkey = 14
oldkey = 20
FOR col = 1 TO 4
rdg = 20
key = 20
LOW 5
LOW 6
LOW 7
LOW 8
HIGH col
INPUT 5
IF IN5 THEN
rdg = col
ELSE
INPUT 6
IF IN6 THEN
rdg = col + 4
ELSE
INPUT 7
IF IN7 THEN
rdg = col + 8
ELSE
INPUT 8
IF IN8 THEN rdg = col + 12
ENDIF
ENDIF
ENDIF
LOW col
IF rdg <> 20 THEN LOOKUP rdg, [noparse][[/noparse]0,1,2,3,10,4,5,6,11,7,8,9,12,14,0,15,13], key
IF (key <> oldkey) THEN
IF (key < 10) THEN
DEBUG BKSP, DEC1 key
ELSE
SELECT key
CASE 10
DEBUG BKSP, BKSP, " A"
CASE 11
DEBUG BKSP, BKSP, " B"
CASE 12
DEBUG BKSP, BKSP, " C"
CASE 13
DEBUG BKSP, BKSP, " D"
CASE 14
DEBUG BKSP, BKSP, " *"
CASE 15
DEBUG BKSP, BKSP, " #"
ENDSELECT
ENDIF
ENDIF
oldkey = key
IF (oldkey = 14) THEN QuitNow
NEXT
LOOP
QuitNow:
DEBUG CR, CR, CR, "done", CR
END
