Bluetooth with the SX
Hey all,
Was wondering if anyone has played around with the Bluetooth modules sold by sparkfun www.sparkfun.com/commerce/product_info.php?products_id=148 with the SX?
I'm planning to buy one when the newer/replacement version is in stock www.sparkfun.com/commerce/product_info.php?products_id=8461.
It looks like its TTL, so i should be able to hook it directly to the SX and start sending serial unless I'm missing something?
I like to build little robots, and its hard to see which LED is flashing or read a tiny LCD display when its bumping about in some unexpected manner for reasons beyond me [noparse]:D[/noparse]
Be so cool to have a real time display to a laptop with:
Course if i got fancy enough i suppose i could even enable control and input values to variables like motor delays and PWM values (mmmmmm).
Reversing and turning randomly (left) because: Left IR detection, Right IR detection Reversing and turning left again because:Left IR detection, Right IR detection Moving forward because: No IR detection Reversing and turning left because: Right IR detection
http://www.a7eng.com/products/embeddedblue/serial/eb501-SER.htm
The antenna adds a little cost but depending upon where you get it from these can be less expensive than the Sparkfun module.
A huge plus for the A7 modules is that they have a standard serial interface as well as both 3.3V and 5V logic level serial connections. It is the same chipset that Parallax uses in their Bluetooth Appmod.
The A7 modules are easy to use and work very well. I used one for my BOB project in SERVO magazine and also with some older 8031 based controller boards.
You can connect the logic level signals directly to the SX processor. Once you pair up this A7 module with your PC bluetooth adapter it looks like another serial port on the PC. From there everything is transparent.
I am going to continue using the A7 modules for other projects and would definitely recommend them!
Robert
