BS2pe + supper carrier board = Problem!
I've just bought a "BS2pe" module and a Basic Stamp "Supper Carrier" Board.
I installed the module on the board but it is not working:
I successfully identified the BS2pe with BS editor's Identify tool.
then I wrote a simple prog . in BS editor to test the module:
' {$STAMP BS2pe}
' {$PBASIC 2.5}
DEBUG "ABCD"
but surprisingly BS editor says "NO BASIC STAMPS FOUND".
I still can successfully identify the module but when I want to run a prog. I get the same error message ("NO BASIC STAMPS FOUND").
I have 10 BS HomeWork board and a BS2+boardBoard of Education and all of them are working well but I don't know what's wrong with my new system (BS2pe module + Basic Stamp Supper Carrier Board).
can you kindly help me with my problem?
I am looking forward to hearing from you soon.
sincerely,
Ali
' {$STAMP BS2pe}
' {$PBASIC 2.5}
DEBUG "ABCD"
sincerely,
Ali
Are you sure you've installed it "right way up" in the Super Carrier? What are you using to power the Super Carrier board?
Tracy Allen
www.emesystems.com
I'm sure I've installed it right.
the new BS2pe does not work with Board of education (BOE) either.
But my old BS2 works with the Super Carrier board. I think it means that my BS2pe is broken. right?
by the way my power supply is a 8V adapter. is something wrong with that?
thank you all,
Ali
