HB-25 Keeps Timing Out !
Hi All,
··········· I have a single HB-25 and I would like to send the command to it and not worry about refreshing, but I have tried to change it from the timeout mode to non-timeout mode using the procedure below without success. Can someone give me a clearer explanation? The jumper is installed. I disconnected servo cable. Then powered up, I removed the jumper and re-applied power. That did not work so I repeated the below only this time the jumper was off so in step 3 I re-installed the jumper. Still timing out.
The Timeout mode can be toggled on and off by following the procedure below. The current state is
stored in an on-board EEPROM and will remain until you toggle it again.
To toggle the state of the Timeout mode:
1. Disconnect the servo input cable from the HB-25. If there is a daisy-chained cable to a
second unit remove it as well. It makes no difference whether the Mode Jumper (J) is
installed.
2. Apply power to the HB-25.
3. With the power on change the state of the Mode Jumper by installing the jumper if it is
removed or removing it if it is installed.
4. Remove and re-apply power.
The timeout state should now be toggled. To change it back, repeat the above steps.
installed.
As for the instructions, remove the signal cable and apply power. While powered up, remove or install the jumper. (do only one or the other!).
Remove power for a few seconds then power up.
Are you sure the behaviour you're seeing is not caused by the stamp program? Perhaps post it and we can have a look.
Cheers,
Tom Sisk
http://www.siskconsult.com
Motor_SR:
PULSOUT HB25, M_Speed
PAUSE 20
PAUSE 20
RETURN
DO : LOOP UNTIL HB25 = 1
LOW HB25
PAUSE 200
I think there may be a situation where the M_speed variable doesn't change from the M_stop value. Perhaps put a debug in the motor subroutine to check.
Alternatively, setup a very small program that controls only the HB-25 and send it some hard values for reverse, stop, forward.
That will allow you to concentrate on getting the HB-25 to behave.
Cheers,
Tom Sisk
Thanks for all the suggestions. I tried hard coding 750 which is stop, then 850 which turns the motor forward and then 650 gave me reverse, but still the HB-25 times out after a few seconds.
Some people have installed a 10 Kohm "pull-down" resistor between the data terminal and ground -- but that's to prevent BS2 transients on the line when the BS2 is powered off.
Edit:· That really is a very nicely documented and formatted program, well done.
On a quick viewing, it looks like you're properly setting the port to an output, and properly controlling the HB25 with PULSOUT.
All I'm left with is either a power problem (your power supply might lack the 10 amps necessary to drive the HB25's, and brown-out reset)
or some logic problem which is resulting in sending resets to the HB-25.
Many people put a:
· SEROUT 16, 16468, [noparse][[/noparse]" Reset! ", CR]
at the start of their program.· This will then let you monitor the "programming port" in the IDE,
to see if your program is resetting.
Post Edited (allanlane5) : 6/9/2008 3:04:11 PM GMT
