Erasing code from eeprom
Frank70
Hello everyone. I finally got my Prop. demo board starting to try some example codes. Well, I downloaded to the eeprom, just to try it and now I can't figure out how to erase it. I looked in the manual and couldn't find anything. do you simply override a program to it, I want to try some new objects but I need to erase this one first ?? I will down load to ram next time so will reset. I tried hitting the reset button but it still wont reset. Thanks for the Help!!
For quick tests program with F10 (loads to memory only) and for long term use (and away from PC) use F11 to program the eeprom as you have done.
Graham
