Why can I not use subrutines in my interrupt rutine when I program in SX/B — Parallax Forums
AtleAtle Posts: 5
edited 2008-06-08 15:11 in General Discussion
I'm trying to call a subrutine from my interrupt rutine but I get an error 16 UNKNOWN COMMAND.
Is it not possible to call a subrutine from the interrupt rutine, and if not, why?
I put in an example program below to illustrate the error I get.
-Atle
' Device Settings
DEVICE SX48, OSCHS3
FREQ 50_000_000
' Variables
Tmp1 VAR Byte
Tmp2 VAR Byte
INTERRUPT 2000
ISR_Start:
' ISR code here
TogglePin
ISR_Exit:
RETURNINT ' {cycles}
PROGRAM Start
' Subroutines / Jump Table
TogglePin SUB
' Program Code
Start:
' initialization code here
TogglePin
TogglePin
' main code here
GOTO Start
' Use: UpdateTimerArray TimerArrayPosition ChannelNr
SUB TogglePin
Toggle RA.1
ENDSUB
  • Peter VerkaikPeter Verkaik Posts: 3,956
    edited 2008-06-07 16:58
    Put the sub definition
    TogglePin SUB
    before the interrupt code.
    regards peter
  • BeanBean Posts: 8,129
    edited 2008-06-07 17:12
    Like this:
    ' Device Settings
    DEVICE SX48, OSCHS3
    FREQ 50_000_000
    ' Variables
    Tmp1 VAR Byte
    Tmp2 VAR Byte
    INTERRUPT 2000
      GOTO ISR_Start
    TogglePin SUB
    ISR_Start:
    ' ISR code here
    TogglePin
    ISR_Exit:
    RETURNINT
    PROGRAM Start
    ' Program Code
    Start:
      TogglePin
      TogglePin
      ' main code here
      GOTO Start
    SUB TogglePin
      Toggle RA.1
    ENDSUB
    Bean
    Did you know that 111,111,111 multiplied by 111,111,111 equals 12345678987654321 ?
    www.iElectronicDesigns.com
    Post Edited (Bean (Hitt Consulting)) : 6/7/2008 8:20:47 PM GMT
    edited 2008-06-07 18:40
    I tried to compile that, there's a GOTO Int_start that should be GOTO ISR_Start.
    edited 2008-06-07 20:19
    Oops,
    Sorry about. Wasn't at a computer with the IDE.
    Bean.
  • JonnyMacJonnyMac Posts: 9,611
    edited 2008-06-08 04:48
    Reminder: There's a template in the SX/B ehlp file that will help you keep everything in the right place.
  • AtleAtle Posts: 5
    This was great, helps me a lot.
    Thank you guys.
    -Atle
