Simple Question, Please help
ill get right to the question:
I got to buttons that share the same ground, but have two different leads.
im not sure how to wire it to the stamp board.
Everything i try isnt working, i only want one of the buttons to flash but they both do. i plugged the ground wire that they both share into P15, then i put the lead next to it on the white part, But that leaves the other lead for the other button no where to go. So i tried putting it next to the other one, but then both the buttons light up, i only want one buttong to light up. can anyone help me?
high 15
pause 250
low 15
but only have the button thats hooked into 15 go off.
- Stephen
So I'm guessing there's some "light source" inside the buttons that "flash". Well, we need to know if those are lamps, or LED's. And if you have some current limiting device (like a resistor) if they ARE LED's, and how much current they take if they're lamps.
maybe its my code or something? im just trying to use somthing simple like this:
high 15
pause 250
low 15
15 [noparse]/noparse]-] [color=gray][noparse][[/noparse][color=green]G[/color [noparse][[/noparse] ][/color]
14 [noparse][[/noparse] ]· [noparse][[/noparse] ]·[noparse][[/noparse] ]
13 [noparse][[/noparse] ]· [noparse][[/noparse] ]·[noparse][[/noparse] ]
12 [noparse][[/noparse] ]· [noparse][[/noparse] ]·[noparse][[/noparse] ]
11 [noparse][[/noparse] ]· [noparse][[/noparse] ]·[noparse][[/noparse] ]
now where do i put the Blue hot wire? i have tried putting it next the the Green hot but they both will hit at the same time. i have tried connecting the 15 pin with the 14 pin making the share the same ground, and having the blue hot wire under the green hot wire. i cant figure it out.
i put:
high 15
pause 250
low 15
i also tried this with them sharing the same ground on 15 and 14:
high 15
low 14
pause 250
low 15
but i cant figure this out....
If you're talking about some kind of lamp, usually the common lead is connected to the Stamp's ground (or Vss) lead. The other lead from the lamp is connected to an I/O pin, usually through some kind of current limiting resistor. For most LEDs, a 330 Ohm resistor is commonly used. Some kinds of Stamp boards (like the HomeWork Board) already have this installed. Most Stamp boards do not have this and you'll have to add your own.
If your lamp is an LED, but with the common lead connected to the LED anodes (common anode), you'll need to connect the common lead to the Stamp's +5V (or Vdd) lead. The other leads are still connected to I/O pins through a 330 Ohm resistor.
In the first case, you set the I/O pin HIGH to turn on the lamp. In the second case, you set the I/O pin LOW to turn on the lamp.
Post Edited (Mike Green) : 6/6/2008 8:35:44 PM GMT
high 15
pause 250
low 15
i put the ground for both of them on the ground for 15. G represents the hot wire for the green button
15 [noparse][[/noparse]-] [noparse][[/noparse]G] [noparse][[/noparse] ]
14 [noparse][[/noparse] ] [noparse][[/noparse] ] [noparse][[/noparse] ]
13 [noparse][[/noparse] ] [noparse][[/noparse] ] [noparse][[/noparse] ]
12 [noparse][[/noparse] ] [noparse][[/noparse] ] [noparse][[/noparse] ]
11 [noparse][[/noparse] ] [noparse][[/noparse] ] [noparse][[/noparse] ]
i put:
high 15
pause 250
low 15
high 15
low 14
pause 250
low 15
- Stephen
Have you tried my suggestion yet?
- Stephen
http://img2.freeimagehosting.net/image.php?cb4a3da26a.jpg
If you take a look at my picutre it helps me explain this a lot better, and youll get a better understanding of what im trying to ask. I have three buttons on a circuit board. buttons 1 and 2 share the same ground, and i cannot seperate this from which reasons i cannot explain. But they have two different positive wires. Now button 3 has its own ground and its own positive wire. I can take the ground wire from button 3 and place it in P15, and then take the positive wire and place it next to it and write a simple script like this.
High 15
Pause 250
Low 15
And that will activate buttons three.
But for button 1 and button two im not sure how to hook them up. I have tried various things with them but everytime i try, i cant get one to activate without the other one activating as well. How can i prevent this? I need to know how to wire this so i can activate button 1 without button 2 activating as well, and vise versa
- Stephen
Franklin: If you look at my pic, you would understand what im saying. I need to hook the ground into the basic stamp to complete the cricuit. I just when i do this, it complete the circuit for the green key "button one1" and the blue key "button 2". I need to know how to prevent this. I dont know how to make it any clearler what im trying to explain...
This description doesn't address what's called contact bounce. The BUTTON statement does that. Read the description in the PBasic manual.
Do not use HIGH or LOW with these input pins. They're in input mode by default. Read about the INPUT statement if you want more info.
