Any Recommendations for Interboard Cabling
I need some help regarding cabling for a Propeller project.
I'm gradually building a MIDI Piano Accordion as real ones are far too expensive.
(I'm also interested in using the Propeller for sound synthesis if things work out, but may need Propeller 2 for this when it appears.)
I'm using the standard Propeller protoboard as the central processor with satellite circuits polling the treble and bass keyboards, using HC4017 and HC165 chips.
This requires 8 lines (including power and ground) and a cable run of 12-18 inches to each satellite circuit. What sort of cabling should I be using?
Should I be using simple shielded multi-core cable, or individually screened cores, ribbon cable, twisted pair or something else. Does it matter at this sort of distance?
Are there any EMI implications?
Any advice much appreciated.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Timothy D. Swieter
www.brilldea.com·- uOLED-IOC, RGB LEDs, TLC5940 driver PCB
www.tdswieter.com
One little spark of imagination is all it takes for an idea to explode
Ribbon cable with interdigitated grounds should be fine for that distance.· Also be sure to have decoupling caps (at least .01uF) across the VSS and VDD of the HC4017 and HC165 IC's.
Beau Schwabe
IC Layout Engineer
I have 2 complicating factors. The first is that I'm hoping to drive 6x HC165 chips spread over 4 separate satellite cards using the same control lines (LOAD/SHIFT & CLOCK) from the Propeller (1 for treble keyboard, 1 for bass keyboard, 2 for dual joysticks and 2 for two banks of couplers(voice switches). The second is that I'm using a matrix of small neodymium magnets with reed switches and 1N4148 signal diodes to detect the key depressions, so I may have to run the satellite circuits at 5V, rather than 3.3V. I'm setting up a plugboard to test this out.
For the SX protoboard, I used ribbon cable soldered to the board with 16 DIP connectors that plug directly to the breadboard. It works reasonably well, although some type of SIP connector plugged into the breadboard would allow a bit mor room.
On the propeller board I used 4, 8 pin SIP connectors, which works very well. One word of caution about using this type of connectors with breadboards. Some connectors will not plug into the breadboard securely, so try plugging the connector into the breadboard before soldering.
