Vista, USB, BS2 & BOE...PITA!
I cannot get the Board of Education with the BASIC Stamp 2 to work on my computer using the USB interface with Vista!!! Please help...I have tried http://forums.parallax.com/forums/default.aspx?f=5&m=207836&r=x, I have tried lowering the BM latency timer to 1...I just cannot get this thing to work! When I click Run -> Identify, it shows yes for both Loopback and Echo, but it doesn't say BASIC Stamp 2, and when I try to run a program, it says BASIC Stamp not detected...I am using BASIC Stamp Editor v2.4, the number on my kit is 27807...my BS2 is revision J, and my BoE is revision C...I have all the updates for Vista (I am using Vista Home Premium)...Any help would be very much appreciated...Thanks...
- Stephen
Btw, the mini-USB to USB cable that I am using is the one that came in the box with the BoE and BASIC Stamp 2...
http://forums.parallax.com/forums/default.aspx?f=15&m=184304
I've had a lot of problems with both Vista and WindowsXP installing an incorrect driver when the hardware is installed prior to installing the drivers.
