Propeller Battery Charger
Philldapill
I'm building a charge regulator for a 28AH deep cycle lead acid battery. It's for a gate opener that does a Smile poor job of charging it from a solar panel, apparently. The solar panel puts out ample juice when I directly connect it to the battery, but if I keep it on, it will boil it. So, I want to make one with the propeller. I have a couple of 14-bit ADC's that I'll be using that are low power and seem ideal for this. The charging seems simple - connect the solar panel to the battery if the voltage falls below X, and disconnect it when the voltage rises above Y. I know there are better charge schemes, like bulk charge, trickle, etc. but this is a first go at it and I'm not going for 99% efficiency.
However, speaking of efficiency, this leads to my next question. I need to devise a way to reduce the power consumption of the whole charger to a minimum. I was thinking using an opamp to watch the voltage from the panel(or current, which ever) and supply power to the propeller when the panel is producing power, AKA during the day. One scheme I thought of was to use a phototransistor to sense ambient light. This would probably be the simplest, but maybe not the most accurate. The other was to sense the voltage from the panel. My thinking is that the opamp won't know if the panel is connected or not to the battery, so if the voltage is ever above 12.6 volts, then there is some power.
Anyway, bottom line, I need to cut the power consumption to a minimum. I'm sure I could do this with an opamp with hysteresis, but my other objective is to be able to log the voltage of the battery throughout the day at around 5 minute intervals or so. That's why I want to use a propeller.
You could set it up so when the prop is not running, the panel is isolated from the battery, so the software must be up and running prior to it commencing a charge.
The prop should be up and running well before there is enough juice to commence charging the battery so you can watch the events at the start and end of the day also.
My 2 cents,
Marty
Lunch cures all problems! have you had lunch?
Then your prop recorder unit can eventually be used for something else.
