Stepper Motor Control
Hey all,
··· I am currently working on a project and would like to hear some insite.· I would like to rotate a brake drum using a stepper motor but with only about 1 degree at a time.· Is it possible to have the stamp control the stepper motor to do that?· I have see the 2 controllers on the site,·http://www.seas.upenn.edu/~robo2005/Electronics%20Lab%203%20v3.doc·and http://www.parallax.com/dl/docs/books/sw/exp/sw26.pdf.
···· Please let me know what you think!
MT
MT
- Stephen
If the number of steps is not mathematically well related to the gear ratio, your ability to position the brake drum at precise locations may not what you want. However, if you're trying to position to within 1 deg with a 360 step per rev motor and a 10:1 gear ratio, you should be fine. (each step of the motor will move the drum 0.1 deg). I think inertia is going to be the hardest thing to control, depending on the strength of the stepper.
If the speed becomes too slow with the geared stepper , you may have to move to a more powerful brushed motor and measure the drum position with an external encoder.
Cheers,
Tom Sisk
http://www.siskconsult.com
