I am wondering if it is possible to send/receive data between Parallax EmbeddedBlue Transceiver AppMod and a normal Bluetooth module we use in our PC??????
Yes. The EmbeddedBlue Transceiver just provides an RFCOMM protocol link (a bidirectional serial port). As long as the Bluetooth (driver) "stack" on your PC supports RFCOMM (as most do), it should work.
is there any Parallax Homework board which has USB not SERIAL????? and if it is then is it possiable to use normal usb module we use in our PC to that board to communicate?????
