Weight Limit of Parallax Servos?
Oldbitcollector (Jeff)
Using Parallax Servos as drive wheels, (like the Boebot) what is
the max weight I can build before I risk damage to the servos?
OBC
New to the Propeller?
Getting started with the Protoboard? - Propeller Cookbook 1.4
Got an SD card? - PropDOS
Need a part? Got spare electronics? - The Electronics Exchange
OBC
I can't imagine them handling two pounds... Perhaps an "official" Parallax test is in order.
OBC
Annoyingly, this includes the soft rubber tires on our Scooba floor washer. Unless we charge & store it in a raised position, the tires get flat spots that cause problems.
You could install the wheel on a shaft of its own with its own bearing and use a coupling between the wheel shaft and the servo. With this type of arrangement, you might also be able to connect the wheel and servo with either a pully drive or gear drive. A pully or gear drive would allow you to also modify the wheel speed/torque to match the load you are expecting.
Another option, if you are using the BOE-Bot chassis is the Tank Tread Kit (#28106)·that Parallax sells. This bolts directly to the BOE-Bot chassis and takes the weight of the robot off the servos. The bogey wheels on the tread carry the load. The only load on the servo is the tension on the treads. Of course, this results in a much slower top speed for the system.
Without specifics of what you are using and what you wish to accomplish, it is difficult to come up with more specific possible solutions.
Thats pretty much my plan, i was just hoping for a cheapskate way of doing things that would be easier to implement. Like , maybe just using an eye bolt round the shaft of the servo to strengthen it. At the low speeds a servo turns at i think chain would be the best bet, just wanted something cheap and simple.
As for specifics, I'm planning to build a back-yard rover type bot from scratch, and at this point i'm pretty open to any design thats really really cheap. Thought someone might have a trick they use to add a lil extra weight to a direct wheel mount servo system.
a solid axle will allow you to add a good payload but to move it uphill you might need to shift it into low gear with meshed sprockett's or even worm driven wheels . in short a solid steel axle thick enough to bare the weight of a horse can be used but unless you can move your bobot its a fine rollerskate for horsey, but with a R/C transmission setup you may just pull the bumper off that old horse. that is trail blazeing at its finest,it may require a chasis modification or even radical reworking but it end's with a more capable more powerfull bott "that is to be desired"......
or how about swaping the direct drive servos with wormdrive or I once made a realy cool bot useing the drive motor's & 100:1 transmission from a power wheels."it openly accepts a solid axle too".
happy building.
