Frequency accuracy
I'm trying to do use Timer to delay, and I have some concerns regarding the accuracy.
I first tried timeoutSec methode, but it seems that it's giving only approx delay, and it can delay for one hour.
So I calculated the low and high value myself using 8,68us tick time. With those values, I got about 18sec/h gap.
After reading to some other posts, I found that is not 8,68 exactly, but 1000000/115200 us. So I redo all my calculations, this time for 10 hours in order to get a beter view. This number is based on the internal 115200 frequency for UAT checking.
I just read the result this morning.
Start at 21:19:09, end at 06:18:06. So my 10 hours delay was, in fact, 9h58m57s. Which mean 63s gap => 6s/h.
It's better, but it's still not accurate enough. I don't want to use an external rtc since I have no more pin available. I have another test running, so I will know the result at 16:19 today.
So my questions are:
- What is the exact internal frequency for the timer? Is it 115200? Based on my last test, seems to be close to 115392.
- Do all the javelins have exactly the same internal frequency? My final application will run with more than one Javelin, and I would like all of them to stay allign.
Here are my calc:
Tick time = 1000000/115200 us
10 Heures:
36000000000 useconds
4147200000 ticks
11110111001100010100000000000000 tickes
High = 1111011100110000 = 0000100011001111 = -2255
Low = 0100000000000000 = 16384
Jean-Marc
Here are my calc:
10 Heures:
4147200000 ticks
Jean-Marc
to interrrupt cycle time of 217/25,000,000 = 8.68 usec
Now the crystal frequence may vary slightly from·25MHz due to temperature variations.
So·the Timer·accuracy is identical to the crystal accuracy + temperature variation.
measured inaccuracy = 6s/h = 6s/3600s = 1/600 = 0.17%
That's not·too bad.
To·keep multiple processors time-aligned, make one processor·the·time-master
and sync the other processors periodically to this time-master.
regards peter
Thanks for your reply. Will have I the same inaccuracy if I get a RTC chip? Or is it more accurate?
JM
and these usually use small 32.768kHz crystals which are very accurate.
regards peter
Thanks for your reply. Does it mean there is many qualities of 32.768kHz crystals? Also, I found DS3234 on the net, do you think that it's something which will be possible to use with the Javelin? The accuracy seems to be ±1min/yr.
JM
Link: http://www.maxim-ic.com/products/timers/ds3234.cfm
Update: Look like it's not a i2c one. This one should be: http://www.maxim-ic.com/quick_view2.cfm/qv_pk/5283
Message Edité (jmspaggi) : 6/4/2008 5:31:36 PM GMT
Be sure to use the correct one for the device.
The device you linked is a very good candidate. Maxim/Dallas has a wide range of rtc chips.
Another option is use a RF receiver to receive time via RF, like DCF77 (europe).
http://www.compuphase.com/mp3/h0420_timecode.htm
regards peter
RF seems to be a good idea. Do you know if we have that in North America?
Also, if I want o buy a DS32C35 from Maxim/Dallas, do you know where I can found that? I don't want to buy 1 000 of then in bulk from Dallas [noparse];)[/noparse]
JM
See here for a receiver circuit:
http://www.ntp-time-server.com/wwvb-receiver/wwvb-receiver.htm
A wwvb receiver connected to basic stamp.
http://www.parallax.com/dl/docs/cols/nv/vol2/col/nv51.pdf
regards peter
Post Edited (Peter Verkaik) : 6/4/2008 6:18:37 PM GMT
Thanks a lot for all this information. Look like for me, I will need to synch with CHU http://en.wikipedia.org/wiki/CHU_(radio_station) since I'm not in the signal range for WWVB (Montreal/QC). Do you know if modules built for CHU exists?
With such signal, I will not need any RTC, I will just have to use an home made internal clock + CHU/WWVB sync.
JM
Coverage: http://tf.nist.gov/stations/wwvbcoverage.htm
