Reading File Fragment
Currently, I have a Memory Stick Datalogger working with the propeller. On the Memory Stick, there is a file, say test.txt. What would be the best way to read a specific number of bytes from the file, but not necessarily from the beginning? For example, I want to read the 100th byte through the 114th byte into RAM. I thought about just reading the first ~150 bytes into a buffer, then bytemoving index 100-114 to the beginning, and bytefilling everything above index 14 with 0. This would probably work, but it seems rather memory inefficient? Any other methods of doing this?
Craig
My system: 1.6 GHz AMD Turion64 X2, 4GB DDR2, 256MB ATI Radeon Graphics card, 15.4" Widescreen HD Screen
I have a duel boot of Ubuntu Linux and Windows Vista. Vista, because it came with the PC, Ubuntu because I like software that works.
"Failure is not an option -- it comes bundled with Windows."
Use The Best...
Linux for Servers
Mac for Graphics
Palm for Mobility
Windows for Solitaire
Craig
Use The Best...
Linux for Servers
Mac for Graphics
Palm for Mobility
If you have the most recent firmware, there is a Seek command that lets you set the file relative address of the next byte to read.
Post Edited (Mike Green) : 6/3/2008 7:18:24 PM GMT
But I could be wrong, anyone know for sure?
Use The Best...
Linux for Servers
Mac for Graphics
Palm for Mobility
All I know about this sort of stuff is from what I read in the manual. You too can be the repository of secret information.
serial.rxFlush serial.str(string("RDF ")) repeat count from 0 to 3 serial.tx(skip.byte[noparse][[/noparse]count]) serial.tx(13) serial.rxFlush serial.str(string("RDF ")) repeat count from 0 to 3 serial.tx(size.byte[noparse][[/noparse]count]) serial.tx(13) serial.rxStr(addr)▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Use The Best...
Linux for Servers
Mac for Graphics
Palm for Mobility
