SparkFun White on Black LCD (Parallel)
does anyone have any experience interfacing to this LCD Display?
http://www.sparkfun.com/commerce/product_info.php?products_id=709
i want to use an sx28.· I am assuming because it uses the HD44780 command set that i should be able to use the example in the sx help file.· Do these type of LCD's typically all pin out the same?
It's Only A Stupid Question If You Have Not Googled It First!!
Post Edited (Brian Carpenter) : 6/3/2008 5:03:55 AM GMT
