Measure of PH with a Basic Stamp.
Hi.
Only to know if may I use a Basic Stamp to read
a PH meter and if you sell the PH-meter.
I you don't sell, please , could you
tell if it is difficult to do make the routine to do that and if you
know an easy interfaz for a PH meter.
Thanks, Mark.
Thanks, Mark.
http://www.vernier.com/probes/ph-bta.html
and an analog protoboard connector
http://www.vernier.com/accessories/access.html?bta-elv&btd-elv&template=basic.html
which can be used to interface Vernier sensors to Basic Stamps. I haven't used the Ph sensor that way, but I've connected a couple of the other Vernier sensors to the ADC inputs of a BS2pe, and it works just fine. Notice that some of the Vernier sensors·have analog connections (BTA) and others digital (BTD). I believe that the Ph sensor will work properly with the BTA connector, but again, I haven't tried it.
