USB reliablity issues with Spin Stamp
Hey all, pulled a new spin stamp and prop clip out of the box today and started loading code. I can hit F7 (identify hardware) and it finds the Propeller version 1 on COM 12 every time. But as a load code into RAM it fails 90% of the time, giving a "No Propellers found" error. Sometimes power cycling the spin stamp helps, but not every time. Sometimes I have to just keep hitting update to RAM over and over until it works.
Any suggestions?
Running Prop Tool v1.1, USB driver FTDI 2.2.4.0
J
Any suggestions?
J
I just updated Parallels and MacOSX, and the problem went away, but I am
not sure which did it.
Prior to that, I found that if I used F8 to compile, then used the LoadRAM button
on the F8 screen, it would work every time. In addition to the things in
troubleshooting that Mike mentioned, these might also help.
Thanks for the trick though, it helps.
J
And everyone else ... It always helps to give a full description of what the configuration is when asking a question because people will most likely assume you're using standard PC hardware and a native Windows OS in the absence of anything to the contrary and answer accordingly.
Luckily Chuck's intervention saved everyone wasting time giving help which would be applicable to a native Windows system but not solve the problem you have.
While agree with the sentiment you will notice that I did post the Prop Tool and FTDI driver version numbers that I was using. While Chuck's work around works, it is not a solution and I have not found one yet. I am reluctant to blame Parallels because I use a wide variety of USB devices without incident, including some higher speed devices.
J
